Since upgrading to 1.16.5 on MacOS 11.6 I get an error "This disc uses a newer version of ACCS+ encryption", even on discs I have opened on an earlier version 1.15.1, I downgraded back to 1.15.1 and can open discs again.
Any ideas why this would be?
Thanks,
Mike
						MakeMKV 1.16.5 Issue opening discs
Re: MakeMKV 1.16.5 Issue opening discs
What drive? Read about LibreDrive and AACS re:"host revocation".
				mjwilcox12
OS device name: /dev/rdisk9
Product: BD-RE BP06LU10
Revision: HL03
Serial number: KVDB1EF4409
Firmware date: 2010-12-06 12:34:56
Highest AACS version: 70
Status: Possible, might be supported in future, but not likely soon
Drive platform: RS1013
Firmware version: HL03-07a120610
Revision: HL03
Without a LibreDrive-capable drive, I guess this needs to be handled the old-fashioned way... submit the MKB dump & wait for a new MakeMKV version?
See this old thread... AACS V64 - host certificate is revoked by your drive for details.
				mjwilcox12
What I'm not getting is that it works in 1.15.1, but not in 1.16.5. Same discs, same drive, same Mac. Only difference is the MakeMKV version.
				LogicalSpock
Same problem today with my LG HL-DT-ST BD-RE BH16NS40. Been a while since I have ripped. Had version 1.15.0. Saw the upgrade notice and upgraded to 1.16.5. Inserted a BR and got the same errors. Went back to 1.15.0 and everything is fine again.
				LogicalSpock
May I add to my previous submitted post that this error was with Windows 10 and my LG BR drive vanished from the device manager after the errors and I was unable to reopen the drive bay to remove the BR disc. Had to reboot the PC to get the BR drive working again.
