UHD FAQ
Phrehdd
Re: UHD FAQ
#16 Post by Phrehdd » Wed Mar 20, 2019 8:13 pm
SamuriHL wrote:
Wed Mar 20, 2019 7:57 pm
Phrehdd wrote:
Wed Mar 20, 2019 7:52 pm
With HDR, is the single MKV file created sufficient for playback (on a 4K tv that supports HRD) via Nvidia Shield TV? Do I need an entire backup of the UHD disc?
An MKV is perfectly fine for HDR playback on the SHIELD. Works in Plex, Kodi with no problems. No need to back up the whole disc.
Thank you much for getting back to me so quickly. Off to get a few more discs taken care of!
mgutt
Re: UHD FAQ
#17 Post by mgutt » Thu Jul 18, 2019 8:08 pm
I'm a little bit confused. In this thread the key files are named as "both KEYDB.cfg and hashed keys are text files" or "KEYDB.cfg or as hashed key". But after I downloaded the file its name is "keys_hashed.txt". Do I need to rename it to "hashed keys" without extension before copying it to the MakeMKV data directory?!
And what is the data directory, "C:\Users\USERNAME\AppData\Roaming\MakeMKV"?
Re: UHD FAQ
#18 Post by d00zah » Thu Jul 18, 2019 8:21 pm
If you note the dates on those discussions, they are VERY old news. Hashed keys are now automatically downloaded, if available, when the disc is scanned.
https://www.makemkv.com/forum/viewtopic ... 854#p75730
Edit: I notice this particular thread is a tad long-in-the-tooth, as well.
mgutt
Re: UHD FAQ
#19 Post by mgutt » Thu Jul 18, 2019 8:39 pm
Thanks. This explains why Planet Earth II was readable ^^
But someone should update the FAQ.
LGans316
Re: UHD FAQ
#20 Post by LGans316 » Thu May 14, 2020 11:52 am
So far I managed to rip about 52 discs (most UHDs and some 3D Blu-rays).
I have encountered 3 failures so far. Thought it was a bad drive but looks like bad discs. What's strange is I had watched these discs in the past in my Panasonic UB820 player without issues. I will be giving all these bad discs a deep clean and retry some of them later and all these discs are US ones (coincidence).
Re: UHD FAQ
#21 Post by Woodstock » Fri May 14, 2021 5:42 pm
While it is not necessary to post a topic in the UHD forum when you send in a file dump .tgz file to svq@makemkv.com, if you do (or reply to an existing one), consider adding the NAME of the .tgz file to your message. The name contains what could be considered a "hash code" of its own, that identifies different disk versions.
As an example, these are file names submitted recently:
MKB20_v70_COSMIC_SIN_AFEC.tgz
MKB20_v72_Spartacus_764B.tgz
A disk from a different distribution may need a different key, and it will generate a different file name.
If you find a topic already started for the title you're trying to rip, check the file name listed - if yours is different, it is important that you also submit the file dump, since it is different than the one already submitted. And go ahead and reply to that topic with the name of the file you submit.
archer
Re: UHD FAQ
#22 Post by archer » Thu May 20, 2021 6:31 am
FYI, the mail servers for makemkv.com have been timing out since Monday, causing the bounces to svq@makemkv.com
Edit: Just saw the post below from Tuesday, so possibly why
viewtopic.php?f=12&t=25298#p108900
robertzombie
Re: UHD FAQ
#23 Post by robertzombie » Wed Oct 13, 2021 1:20 pm
Is it possible to rip a UHD disc and *ignore* the Dolby Vision layer, resulting in an MKV file with just the HDR video?
Zorro
Re: UHD FAQ
#24 Post by Zorro » Wed Dec 08, 2021 7:18 pm
MakeMKV cannot decrypt The Guns of Navarone (4K UHD) (purchased from Amazon) which was recently released a few weeks ago. Normally, MakeMKV is quite prompt with UHD disc support, but for this release it still shows:
MakeMKV v1.16.5 win(x64-release) started
Saved AACS dump file as .MakeMKV/MKB20_v76_Guns_of_Navarone_16A1.tgz
Please advise.
Re: UHD FAQ
#25 Post by d00zah » Wed Dec 08, 2021 7:32 pm
Please advise.
It's all covered in the 1st post of this topic... specifically the Hashed Keys section.
djdude199
Re: UHD FAQ
#26 Post by djdude199 » Sat Apr 23, 2022 7:36 am
Under UHD Basics, I can't get to the firmware link. It shows up in a russian alphabet. Please advise
Boogie2005
Re: UHD FAQ
#27 Post by Boogie2005 » Mon May 16, 2022 4:13 pm
Hello, I have sent a mail with my tgz 2 times now. Unfortunately I have not received an answer if and when my UHD BD will work. It is a Pitch Back UHD special edition from Turbine. What do I have to write in the mail so that the ripping will work soon?
Unfortunately, my English is not very good.
See here:
viewtopic.php?p=122479#p122479
Re: UHD FAQ
#28 Post by d00zah » Mon May 16, 2022 4:31 pm
See here:
Did you read the 1st post of this thread? It explains "the process", ~how long it takes, what might go wrong. Unlikely you will ever get a response to an svq submission email (other than the key automatically downloading when it's available). I believe most of the questions you've asked were actually covered earlier in the thread you referenced.
Here's additional info IF you encounter a problem w/ downloading keys... Fixing Volume Key is Unknown
charnathan
Re: UHD FAQ
#29 Post by charnathan » Tue Feb 13, 2024 2:49 am
I feel like the first post of this thread needs ton include a statement about the sleep bug associated with triple layer discs.
There should be enough data collected from drive sellers to be able to accurately say which drives have no issue with triple layer discs. From what I've seen, only UHD official drives have no issues, but I don't own ever UDH friendly drive to test out.
Re: UHD FAQ
#30 Post by SamuriHL » Tue Feb 13, 2024 3:19 am
Pioneer drives have the least problems.
Sent from my SM-S928U1 using Tapatalk
