Scsi error
RonnieA
Scsi error
Post by RonnieA » Tue Dec 07, 2021 12:47 pm
I've read a few posts about the Scsi error - illegal request but can't see that any had a resolution. Anyone know if there's a fix for the following:
MakeMKV v1.16.5 darwin(x64-release) started
Debug logging enabled, log will be saved as /Users/RonnieA/MakeMKV_log.txt
Optical drive "DVD+R-DL HL-DT-ST DVDRW GX50N RR06 KZ5EAQA4844d" opened in OS access mode.
DEBUG: Code 101019395 at %"W67I`+,,'%Cb;iqN:29395195
DEBUG: Code 101019395 at %"W67I`+,,'%Cb;iqN:29393792
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading 'DVD+R-DL HL-DT-ST DVDRW GX50N RR06 KZ5EAQA4844' at offset '1048576'
The drive I'm using is Apple's USB Superdrive which recognises and plays all the discs I've tried but all are coming up with this Scsi error in MakeMKV.
Any guidance much appreciated.
Added debug log in case it offers any help:
Debug log started at Tue Dec 7 15:34:10 2021 , written by MakeMKV v1.16.5 darwin(x64-release)
001005:0000 MakeMKV v1.16.5 darwin(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///Users/RonnieA/MakeMKV_log.txt
Network access is ENABLED, CURL version 7.77.0/(SecureTransport) LibreSSL/2.8.3/1.42.0 (x86_64-apple-darwin21.0) , proxy server not set.
002010:0000 Optical drive "DVD+R-DL HL-DT-ST DVDRW GX50N RR06 KZ5EAQA4844d" opened in OS access mode.
No SDF v07e: HL-DT-ST_DVDRW__GX50N_RR06_201407211334_KZ5EAQA4844
No auto SDF v07e: HL-DT-ST_DVDRW__GX50N_RR06_201407211334_KZ5EAQA4844
DEBUG: Code 0 at tAW//yQ,~P>EnV=9":121264142
DEBUG: Code 0 at _wXRS,@^*L(w1+@q:213136769
SDF id v07e: HL-DT-ST_DVDRW__GX50N_RR06_201407211334_KZ5EAQA4844
001003:0020 DEBUG: Code 101019395 at _wXRS,@^*L(w1+@q:29403291
001003:0020 DEBUG: Code 101019395 at [;8I:%i(<LqU|.bx:213130559
Re: Scsi error
Post by dcoke22 » Tue Dec 07, 2021 8:46 pm
What does MakeMKV say about the drive on the main screen before you open a disc?
RonnieA
Re: Scsi error
Post by RonnieA » Wed Dec 08, 2021 9:12 am
Thanks for looking dcoke22. Screenshot before disc inserted attached.
Screenshot 2021-12-08 at 09.10.53.png (233 KiB) Viewed 8803 times
Re: Scsi error
Post by dcoke22 » Wed Dec 08, 2021 3:20 pm
The GX50N is the LG made drive Apple has used in the SuperDrive for a long time. It should work with MakeMKV, although I've never tried to use one.
As foolish as it sounds, have you tried rebooting your computer? Also, is the drive plugged into your computer directly or via a USB hub? When used with MakeMKV USB powered drives can sometimes be wanting for more power than a USB port can provide. This is why USB powered drives that are not Apple's SuperDrive often come with a Y-cable that lets people plug the drive into two ports, to use the power from both of them.
RonnieA
Re: Scsi error
Post by RonnieA » Wed Dec 08, 2021 3:25 pm
Thanks. . Drive is connected via USB 3.0 port. I'll try a soft then hard reboot to see if that helps.
