Can't find usable optical drive
boowho
Post by boowho » Mon Dec 06, 2021 7:15 pm
Using the following Windows 10 batch file command: \users\bill\makemkvcon64.exe iso:\Users\bill\AmericanPresident.iso \Users\bill\AmericanPresident\
As you can see no optical drive is referenced in the entire command.
I'm simply trying to convert an iso on a hard drive in \users\bill to an MKV file onto the same drive in \users\bill\AmericanPresident.
I can attach the complete batch file if that would help anyone wanting to look at my problem.
Help??
THANKS!!!!
Re: Can't find usable optical drive
Post by MartyMcNuts » Tue Dec 07, 2021 9:42 pm
Help??
THANKS!!!!
The ISO needs to be mounted on a virtual drive. MakeMKV doesn't work directly with ISO files, only discs (or virtual discs). Try VirtualCloneDrive. It's free and easy.
Post by d00zah » Tue Dec 07, 2021 10:03 pm
I need to reluctantly disagree w/ you here. MakeMKV does just fine w/ unmounted .iso files. Just opened one as a test (in case memory was failing in my dotage). Batch converted >1000 of 'em years ago. I suspect something is off w/ the cmd line. YMMV
Post by MartyMcNuts » Tue Dec 07, 2021 10:11 pm
You could be right there d00zah. I don't think I've ever tried to open one. I always mount them as I didn't think it was possible with MakeMKV.
If that's the case, you would probably need to see boowho's batch file.
Post by d00zah » Tue Dec 07, 2021 10:41 pm
Based on:
C:\Program Files (x86)\MakeMKV>makemkvcon64.exe
Use: makemkvcon [switches] Command [Parameters]
Commands:
  info <source>
      prints info about disc
  mkv <source> <title id> <destination folder>
      saves a single title to mkv file
  backup <source> <destination folder>
      backs up disc to a hard drive
  f <args>
      run universal firmware tool
Source specification:
  iso:<FileName>    - open iso image <FileName>
  file:<FolderName> - open files in folder <FolderName>
  disc:<DiscId>     - open disc with id <DiscId> (see list Command)
  dev:<DeviceName>  - open disc with OS device name <DeviceName>
Switches:
  -r --robot        - turn on "robot" mode, see http://www.makemkv.com/developers
the OP's cmd line example is missing :
C:\Program Files (x86)\MakeMKV>makemkvcon64.exe mkv iso:"D:\NewStuff\[ISO]\Alita- Battle Angel (2019)\Alita- Battle Angel (2019).i
so" 1 "D:\NewStuff\[ISO2MKV]"
MakeMKV v1.16.5 win(x64-release) started
Calculated BUP offset for VTS #0 does not match one in IFO header.
Title #1 has length of 420 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Cells 48-end were skipped due to cell commands (structure protection?)
Complex multiplex encountered - 3 cells and 101 VOBUs have to be scanned. This may take some time, please be patient - it can't be
 avoided.
Title #2 was added (41 cell(s), 2:01:33)
Angle #2 was added for title #2
Angle #3 was added for title #2
Title #4/1 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #4/2 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #4/3 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #4/4 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #4/5 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #4/6 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #4/7 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #4/8 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #4/9 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #4/10 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #4/11 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #4/12 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #4/13 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #6 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #7 has length of 10 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #8 has length of 5 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #9/2 has length of 4 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #10 has length of 8 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #31 has length of 306 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #32 has length of 200 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #33 has length of 149 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #34 has length of 173 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #36 has length of 1247 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Saving 1 titles into directory file://D:\NewStuff\[ISO2MKV]
1 titles saved
Copy complete. 1 titles saved.
Post by MartyMcNuts » Tue Dec 07, 2021 11:16 pm
Based on:
Commands:
  info <source>
  f <args>
Switches:
 avoided.
1 titles saved
Good to know, d00zah! Hopefully that will help out boowho.
boowho
Post by boowho » Tue Dec 07, 2021 11:22 pm
Thanks to ALL of you responded with helpful ideas.
However I found a front end GUI that handled batchmkvcon64 just fine so I went with that.
Started it last night before bed and viola! woke up with 85 iso's converted this morning.
Thanks again everybody....
