Using the following Windows 10 batch file command: \users\bill\makemkvcon64.exe iso:\Users\bill\AmericanPresident.iso \Users\bill\AmericanPresident\
As you can see no optical drive is referenced in the entire command.
I'm simply trying to convert an iso on a hard drive in \users\bill to an MKV file onto the same drive in \users\bill\AmericanPresident.
I can attach the complete batch file if that would help anyone wanting to look at my problem.
Help??
THANKS!!!!
Can't find usable optical drive
Re: Can't find usable optical drive
The ISO needs to be mounted on a virtual drive. MakeMKV doesn't work directly with ISO files, only discs (or virtual discs). Try VirtualCloneDrive. It's free and easy.boowho wrote: ↑Mon Dec 06, 2021 7:15 pmUsing the following Windows 10 batch file command: \users\bill\makemkvcon64.exe iso:\Users\bill\AmericanPresident.iso \Users\bill\AmericanPresident\
Help??
THANKS!!!!
I need to reluctantly disagree w/ you here. MakeMKV does just fine w/ unmounted .iso files. Just opened one as a test (in case memory was failing in my dotage). Batch converted >1000 of 'em years ago. I suspect something is off w/ the cmd line. YMMVMartyMcNuts wrote: ↑Tue Dec 07, 2021 9:42 pmThe ISO needs to be mounted on a virtual drive. MakeMKV doesn't work directly with ISO files, only discs (or virtual discs). Try VirtualCloneDrive. It's free and easy.
You could be right there d00zah. I don't think I've ever tried to open one. I always mount them as I didn't think it was possible with MakeMKV.d00zah wrote: ↑Tue Dec 07, 2021 10:03 pmI need to reluctantly disagree w/ you here. MakeMKV does just fine w/ unmounted .iso files. Just opened one as a test (in case memory was failing in my dotage). Batch converted >1000 of 'em years ago. I suspect something is off w/ the cmd line. YMMVMartyMcNuts wrote: ↑Tue Dec 07, 2021 9:42 pmThe ISO needs to be mounted on a virtual drive. MakeMKV doesn't work directly with ISO files, only discs (or virtual discs). Try VirtualCloneDrive. It's free and easy.
If that's the case, you would probably need to see boowho's batch file.
Based on:
the OP's cmd line example is missing :
mkv <source> <title id> <destination folder>
saves a single title to mkv file
C:\Program Files (x86)\MakeMKV>makemkvcon64.exe
Use: makemkvcon [switches] Command [Parameters]
Commands:
info <source>
prints info about disc
backup <source> <destination folder>
backs up disc to a hard drive
f <args>
run universal firmware tool
Source specification:
iso:<FileName> - open iso image <FileName>
file:<FolderName> - open files in folder <FolderName>
disc:<DiscId> - open disc with id <DiscId> (see list Command)
dev:<DeviceName> - open disc with OS device name <DeviceName>
Switches:
-r --robot - turn on "robot" mode, see http://www.makemkv.com/developers
C:\Program Files (x86)\MakeMKV>makemkvcon64.exe mkv iso:"D:\NewStuff\[ISO]\Alita- Battle Angel (2019)\Alita- Battle Angel (2019).i
so" 1 "D:\NewStuff\[ISO2MKV]"
MakeMKV v1.16.5 win(x64-release) started
Calculated BUP offset for VTS #0 does not match one in IFO header.
Title #1 has length of 420 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Cells 48-end were skipped due to cell commands (structure protection?)
Complex multiplex encountered - 3 cells and 101 VOBUs have to be scanned. This may take some time, please be patient - it can't be
avoided.
Title #2 was added (41 cell(s), 2:01:33)
Angle #2 was added for title #2
Angle #3 was added for title #2
Title #4/1 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #4/2 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #4/3 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #4/4 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #4/5 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #4/6 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #4/7 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #4/8 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #4/9 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #4/10 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #4/11 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #4/12 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #4/13 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #6 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #7 has length of 10 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #8 has length of 5 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #9/2 has length of 4 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #10 has length of 8 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #31 has length of 306 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #32 has length of 200 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #33 has length of 149 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #34 has length of 173 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #36 has length of 1247 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Saving 1 titles into directory file://D:\NewStuff\[ISO2MKV]
1 titles saved
Copy complete. 1 titles saved.
Good to know, d00zah! Hopefully that will help out boowho.d00zah wrote: ↑Tue Dec 07, 2021 10:41 pmBased on:
the OP's cmd line example is missing :Code: Select all
C:\Program Files (x86)\MakeMKV>makemkvcon64.exe Use: makemkvcon [switches] Command [Parameters] Commands: info <source> prints info about disc mkv <source> <title id> <destination folder> saves a single title to mkv file backup <source> <destination folder> backs up disc to a hard drive f <args> run universal firmware tool Source specification: iso:<FileName> - open iso image <FileName> file:<FolderName> - open files in folder <FolderName> disc:<DiscId> - open disc with id <DiscId> (see list Command) dev:<DeviceName> - open disc with OS device name <DeviceName> Switches: -r --robot - turn on "robot" mode, see http://www.makemkv.com/developers
C:\Program Files (x86)\MakeMKV>makemkvcon64.exe mkv iso:"D:\NewStuff\[ISO]\Alita- Battle Angel (2019)\Alita- Battle Angel (2019).i so" 1 "D:\NewStuff\[ISO2MKV]" MakeMKV v1.16.5 win(x64-release) started Using direct disc access mode Calculated BUP offset for VTS #0 does not match one in IFO header. Title #1 has length of 420 seconds which is less than minimum title length of 1500 seconds and was therefore skipped Cells 48-end were skipped due to cell commands (structure protection?) Complex multiplex encountered - 3 cells and 101 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided. Title #2 was added (41 cell(s), 2:01:33) Angle #2 was added for title #2 Angle #3 was added for title #2 Title #4/1 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped Title #4/2 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped Title #4/3 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped Title #4/4 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped Title #4/5 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped Title #4/6 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped Title #4/7 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped Title #4/8 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped Title #4/9 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped Title #4/10 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped Title #4/11 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped Title #4/12 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped Title #4/13 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped Title #6 has length of 7 seconds which is less than minimum title length of 1500 seconds and was therefore skipped Title #7 has length of 10 seconds which is less than minimum title length of 1500 seconds and was therefore skipped Title #8 has length of 5 seconds which is less than minimum title length of 1500 seconds and was therefore skipped Title #9/2 has length of 4 seconds which is less than minimum title length of 1500 seconds and was therefore skipped Title #10 has length of 8 seconds which is less than minimum title length of 1500 seconds and was therefore skipped Title #31 has length of 306 seconds which is less than minimum title length of 1500 seconds and was therefore skipped Title #32 has length of 200 seconds which is less than minimum title length of 1500 seconds and was therefore skipped Title #33 has length of 149 seconds which is less than minimum title length of 1500 seconds and was therefore skipped Title #34 has length of 173 seconds which is less than minimum title length of 1500 seconds and was therefore skipped Title #36 has length of 1247 seconds which is less than minimum title length of 1500 seconds and was therefore skipped Operation successfully completed Saving 1 titles into directory file://D:\NewStuff\[ISO2MKV] 1 titles saved Copy complete. 1 titles saved.
Thanks to ALL of you responded with helpful ideas.
However I found a front end GUI that handled batchmkvcon64 just fine so I went with that.
Started it last night before bed and viola! woke up with 85 iso's converted this morning.
Thanks again everybody....
