Blue Ray Rip Speed
hescominsoon
Blue Ray Rip Speed
MOt of hte drives i see are 6 or 8x. are there any UHD friendly drives faster in read speeds?
Re: Blue Ray Rip Speed
You looking for CLAIMS of faster speed, or actually being able to ACHIEVE faster speeds?
with the speed unlock on a WH16NS60 you can rip at 12xhescominsoon wrote: ↑Sun Dec 05, 2021 10:48 pmMOt of hte drives i see are 6 or 8x. are there any UHD friendly drives faster in read speeds?
I've only ever reached 12x rip speeds with single layer discs, fwiw.
i seen it on dual layer discs. did you do the speed unlock? you have to do it in the registry
hescominsoon
right the current drive i have is limited by it's usb 2.0 interface. I ma going to be purchasing one from the person that sells pre-flashed drives..just wanted to make sure i can get faster speeds if i am going to spend the money..
I'm not running Windows, so I don't have a registry. I'm running the MK firmware on my WH16NS60 drive, as well as a BU40N (via SATA, no USB). Multi-layer discs always top out in the 6x-7x range for me.Billycar11 wrote: ↑Mon Dec 06, 2021 5:07 ami seen it on dual layer discs. did you do the speed unlock? you have to do it in the registry
Linux instructions here too viewtopic.php?f=19&t=22689#p93350demon wrote: ↑Tue Dec 07, 2021 6:53 pmI'm not running Windows, so I don't have a registry. I'm running the MK firmware on my WH16NS60 drive, as well as a BU40N (via SATA, no USB). Multi-layer discs always top out in the 6x-7x range for me.Billycar11 wrote: ↑Mon Dec 06, 2021 5:07 ami seen it on dual layer discs. did you do the speed unlock? you have to do it in the registry
Only do it for you WH16NS60 Dont do it on the BU40N
hescominsoon
i flashed a firmware i found on here..the BD read speeds are now as fast as its USB 2.0 interface will allow..
I'm having another issue..but i'll start a new thread on that.
Good to know, thanks.Billycar11 wrote: ↑Tue Dec 07, 2021 11:21 pmLinux instructions here too viewtopic.php?f=19&t=22689#p93350demon wrote: ↑Tue Dec 07, 2021 6:53 pmI'm not running Windows, so I don't have a registry. I'm running the MK firmware on my WH16NS60 drive, as well as a BU40N (via SATA, no USB). Multi-layer discs always top out in the 6x-7x range for me.Billycar11 wrote: ↑Mon Dec 06, 2021 5:07 ami seen it on dual layer discs. did you do the speed unlock? you have to do it in the registry
