Step-by-step guide for the best (IMHO) drive: LG WH16NS60
Locked
Re: Step-by-step guide for the best (IMHO) drive: LG WH16NS60
#121 Post by Billycar11 » Fri Oct 09, 2020 7:15 am
BradM wrote: Fri Oct 09, 2020 6:45 am I have firmware version 1.03 of this drive. I am able to find the necessary files and follow the directions precisely. I can select and open the file in the flashing utility but when I click the go button I receive a pop up message of "Checksum is mismatched. Drive will go into BOOT mode. Please retry again" I have restarted and retired multiple times with the same result. Any ideas of what could be wrong?
this guide is out dated follow mine the pinned one: https://www.makemkv.com/forum/viewtopic ... 16&t=19634
i also offer a self flash kit
Korringadinga
#122 Post by Korringadinga » Mon Dec 06, 2021 12:30 am
Hello and thank you for all of your hard work! I could use a little assistance and will make this as short as possible.
I purchased the lg WH16NS60 which came with the 1.03fw preinstalled. I have run the BH14NS40_N1.00-A4_patched.exe. but there was no file for the WH16NS60. I did find a .bin file for the NS60 (HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010) but no matter which patch I attempt I get an error.
CheckSum is mismatched. Drive will go to BOOT mode. Please retry again.
One last piece to the puzzle is I have an Asus BW-16D1X-U drive that I am using for an external enclosure. I removed the old Pioneer drive and inserted the LG.
Product: BD-RE WH16NS60
Revision: 1.03
Serial number: xxxxxxxxxxxx
Firmware date: 2120-05-08 10:10
Highest AACS version: 76
Harware support: Yes
Firmware support: No
Firmware version: 1.03
Thank you for your help once again :) :D
#123 Post by MartyMcNuts » Mon Dec 06, 2021 3:16 am
Korringadinga wrote: Mon Dec 06, 2021 12:30 am Hello and thank you for all of your hard work! I could use a little assistance and will make this as short as possible.
Revision: 1.03
This thread is obsolete!!!
Please use the SDFtool Flasher and flash the drive to WH16NS60 1.02-MK firmware.
turntable97
#124 Post by turntable97 » Mon Dec 13, 2021 2:07 am
Are there any advantages in upgrading from 1.00 to 1.02MK (or even 1.03MK, if there is one)?
#125 Post by Billycar11 » Mon Dec 13, 2021 4:24 am
turntable97 wrote: Mon Dec 13, 2021 2:07 am Are there any advantages in upgrading from 1.00 to 1.02MK (or even 1.03MK, if there is one)?
No and stop bumping this thread it was out dated the day it came out
Locked
