Blue Ray Rip Speed
hescominsoon
Blue Ray Rip Speed
Post by hescominsoon »
MOt of hte drives i see are 6 or 8x. are there any UHD friendly drives faster in read speeds?
Re: Blue Ray Rip Speed
You looking for CLAIMS of faster speed, or actually being able to ACHIEVE faster speeds?
hescominsoon wrote: Sun Dec 05, 2021 10:48 pm MOt of hte drives i see are 6 or 8x. are there any UHD friendly drives faster in read speeds?
with the speed unlock on a WH16NS60 you can rip at 12x
demon
Post by demon »
I've only ever reached 12x rip speeds with single layer discs, fwiw.
demon wrote: Mon Dec 06, 2021 4:56 am I've only ever reached 12x rip speeds with single layer discs, fwiw.
i seen it on dual layer discs. did you do the speed unlock? you have to do it in the registry
hescominsoon
right the current drive i have is limited by it's usb 2.0 interface. I ma going to be purchasing one from the person that sells pre-flashed drives..just wanted to make sure i can get faster speeds if i am going to spend the money..:)
demon
Post by demon »
Billycar11 wrote: Mon Dec 06, 2021 5:07 am i seen it on dual layer discs. did you do the speed unlock? you have to do it in the registry
I'm not running Windows, so I don't have a registry. I'm running the MK firmware on my WH16NS60 drive, as well as a BU40N (via SATA, no USB). Multi-layer discs always top out in the 6x-7x range for me.
demon wrote: Tue Dec 07, 2021 6:53 pm
Linux instructions here too viewtopic.php?f=19&t=22689#p93350
Only do it for you WH16NS60 Dont do it on the BU40N
hescominsoon
i flashed a firmware i found on here..the BD read speeds are now as fast as its USB 2.0 interface will allow..:) I'm having another issue..but i'll start a new thread on that.
demon
Post by demon »
Billycar11 wrote: Tue Dec 07, 2021 11:21 pm
Good to know, thanks.
