I am unsure if I did it correctly. I read the tutorials, downloaded the required files and ran the application. made a backup and then ran the the file for my machine. Can anyone inform me if I succeeded or not? Thank you for your time.
OS device name: F:
Product: BD-RE WH14NS40
Revision: 1.05
Serial number: KLPL5C85520
Firmware version: 1.05
LG WH14NS40: Did I do it correctly?
Re: LG WH14NS40: Did I do it correctly?
Can't tell from this.
I can tell you you will still have the sleep bug you did not follow my recommend firmware.
But if your drive still sees discs your fine if not you didn't read the requirements
John Briggs
Ok, so what was the recommended? I read the best I could and used the software. I backed up. Understand that this is all foreign to me so understanding is a learning process for me. Discs read as far as CDs go. Have not had a chance to test anything else. I was unsure what the sleep bug was or how it occurs.Billycar11 wrote: ↑Sun Dec 05, 2021 9:11 pmCan't tell from this.
John Briggs wrote: ↑Mon Dec 06, 2021 2:04 am
sleep bug is also covered in guide read it linked belowBillycar11 wrote: ↑Mon May 27, 2019 5:20 amRecommended Firmware to flash for MakeMKV:
WH16NS60 on any Firmware directly to > WH16NS60 1.02MK
WH16NS40 on any Firmware directly to > WH16NS60 1.02MK
BH16NS55 on any Firmware directly to > WH16NS60 1.02MK
Asus BW-16D1HT on any Firmware directly to > Asus BW-16D1HT 3.10MK
BU40N on any Firmware directly to > BU40N 1.03MK
BP50NB40 to > BP50NB40-NB50-1.03MK then to > BP60NB10 1.02MK or 1.00MK
BP60NB10 on any Firmware directly to > BP60NB10 1.02MK
John Briggs
Yeah, went back and looked. I think I did it right.
OS device name: F:
Product: BD-RE WH16NS60
Revision: 1.02
Firmware version: 1.02
John Briggs wrote: ↑Mon Dec 06, 2021 5:35 amYeah, went back and looked. I think I did it right.
yeah now you wont have the sleep bug and it will be fasterDrive Information
OS device name: F:
Revision: 1.02
John Briggs
Thank you Billycar11 for taking the time to help me out. I did indeed notice a speed change in ripping CDs after I did the second and last update to what you recommended.
