chros
Post by chros » Sun Nov 28, 2021 11:39 am
quietvoid wrote: Mon Nov 15, 2021 3:03 pm You can try this sample: https://mega.nz/file/cY1gEZzQ#eJIRMpZ2X ... PaGtY_35gU
The eagle's beak looks noticeably better in the internal player compared to the Firestick for me.
Next step is probably to try figuring out what's happening and if it can be prevented.
Yes, it looks slightly different via stick4k, but that's what I saw with other contents as well, not sure why.
Was this the 10.000 nits version or the 1000/4000 one?
On a different note, Stacey here mentioned again, that there is a setting (I guess in the RPU) with which the DoVi tonemapping can be turned off, do you know which one?
Here is a calibration pattern sample, that should be like it.
This way I guess we can create calibration samples from hdr10 ones.
quietvoid
Post by quietvoid » Sun Nov 28, 2021 1:30 pm
chros wrote: Sun Nov 28, 2021 11:39 am Yes, it looks slightly different via stick4k, but that's what I saw with other contents as well, not sure why.
That was the 10 000 nits version.
I'm not sure what flags would actually disable tonemapping.
IIRC an empty profile 8 RPU like those created by 'generate' are tonemapping every detail, but usually with a dimmer APL.
We'll probably have to wait for the new disc, unless someone tries to ask Stacey how it works.
Buzzie
Post by Buzzie » Mon Nov 29, 2021 1:59 pm
Anybody that can help me?
I am trying to accomplish the following :
What i would like to achieve with Dovi tool or any other is to download a WEB-DL from any source, take out the DV metadata and add it to the UHD remux so that those versions have DV too.
What i did so far are the following steps:
c:\Dolby-Vision-Tools\ffmpeg\bin\ffmpeg.exe -i "c:\temp\DV_WEB-DL.mkv" -c:v copy -vbsf hevc_mp4toannexb -f hevc c:\temp\DV.hevc
extracted the video from the UHD and named it HDR10.hevc
c:\Dolby-Vision-Tools\dovi_tool.exe -m 3 extract-rpu c:\temp\DV.hevc
made a edited.json file for the RPU
c:\Dolby-Vision-Tools\dovi_tool.exe editor -i c:\temp\RPU.bin -j c:\temp\edited.json --rpu-out c:\temp\RPU-edited.bin
c:\Dolby-Vision-Tools\dovi_tool.exe inject-rpu -i c:\temp\HDR10.hevc --rpu-in c:\temp\RPU-edited.bin
Lastly copied the HDR10.hevc file to the extracted contents of the UHD and used mkvtoolnix to make a new MKV
This one did not have the DV info.
What am i doing wrong?
Thanks again !
chros
Post by chros » Mon Nov 29, 2021 3:24 pm
quietvoid wrote: Sun Nov 28, 2021 1:30 pm
Thanks, so you didn't see anything related in the attached sample?
quietvoid
Post by quietvoid » Mon Nov 29, 2021 5:44 pm
chros wrote: Mon Nov 29, 2021 3:24 pm Thanks, so you didn't see anything related in the attached sample?
Am I supposed to check every RPU frame?
There's nothing indicating a change in the video itself. It's just a static patch.
The metadata suggests the same thing.
chros
Post by chros » Mon Nov 29, 2021 7:46 pm
quietvoid wrote: Mon Nov 29, 2021 5:44 pm
No, you aren't, at least this is what I thought. Thanks for checking!
comorla45
Post by comorla45 » Thu Dec 02, 2021 8:57 am
Buzzie wrote: Mon Nov 29, 2021 1:59 pm Anybody that can help me?
Thanks again !
Yesterday I was playing a bit around with this "hybrid" format and I will describe what I have done. Be aware however, that I lack all knowledge regarding multimedia files, this was just my 4 hour experiment for fun.
1. I got two identical copies of Web-DL Foundation E01, one in MP4 Dolby Vision, second in MKV HDR10 format.
2. I extracted audio using tsMuxeR.
3. I used FFMPEG to extract DV.hevc and HDR10.hevc
4. Using DoVi Tool I extracted RPU from DV.hevc.
5. I injected RPU into HDR10.hevc using DoVi Tool.
6. I muxed all together (HDR10_DV.hevc + audio) into M2TS cointainer.
Why M2TS? My LG OLED will only recognize Dolby Vision in MP4 or M2TS container, not in MKV.
Using this muxed hybrid hdr10-dv +ac3 audio file in M2TS container, I managed to get DV recognized by my LG TV and at the same time fallback to HDR10 on my phone that does not support DV.
I had to use newest night release of tsMuxeR, regular release displayed error when opening hdr10_dv.hevc video stream. This is what MediaInfo says about this hybrid file:
@Buzzie
I can not yet reply to DM, so I will post my commands here:
Command to extract DV.hevc:
ffmpeg.exe -y -i DV_file.mp4 -an -c:v copy -vbsf hevc_mp4toannexb -f hevc DV.hevc
Command to extract RPU:
dovi_tool.exe -m 3 extract-rpu DV.hevc
Command to extract HDR10.hevc:
ffmpeg -i HDR_file.mkv -c:v copy hdr.hevc
Command to inject RPU into HDR10:
dovi_tool.exe inject-rpu -i hdr.hevc --rpu-in RPU.bin -o output.hevc
All files were in the same folder (ffmpeg, dovi tools, mp4, mkv etc) so no paths are specified, just filenames.
Buzzie
Post by Buzzie » Fri Dec 03, 2021 7:56 am
comorla45 wrote: Thu Dec 02, 2021 8:57 am
Thanks again !
@Buzzie
Thanks pal !!
I got it to work.
First it didnt work when i tried to make an MKV......but with m2ts and nightly tsmuxer it worked.
But since i am taking out the DV metadata and add it to MKV Remux i had to use mkvtoolnix but it didnt work.
I was still using an old version so i downloaded the latest version and bam !!
Captain America Civil War in 2160 with Dolby Vision Remux :)
comorla45
Post by comorla45 » Fri Dec 03, 2021 2:05 pm
Thats great to hear! Can you share more about your setup? Do you play via Plex, from USB or some other method? What kind of TV do you have? Thanks!
In my case I use Plex to stream to my TV and mobile phone.
Buzzie
Post by Buzzie » Sat Dec 04, 2021 1:26 pm
comorla45 wrote: Fri Dec 03, 2021 2:05 pm Thats great to hear! Can you share more about your setup? Do you play via Plex, from USB or some other method? What kind of TV do you have? Thanks!
Sure !
I use Kodi on my Nvidia Shield 2019 Pro to watch on my LG C1 tv
DolbyVisionFTW
Post by DolbyVisionFTW » Sat Dec 04, 2021 6:22 pm
Buzzie wrote: Sat Dec 04, 2021 1:26 pmI use Kodi on my Nvidia Shield 2019 Pro to watch on my LG C1 tv
Which version of kodi do you use that supports Dolby Vision playback?
Thanks.
Buzzie
Post by Buzzie » Sat Dec 04, 2021 9:05 pm
DolbyVisionFTW wrote: Sat Dec 04, 2021 6:22 pm
Thanks.
I use Kodi 19.3 from this site.
Its an altered version of Kodi that installs next to the Google Play Store version so you can easily test it
https://www.kodinerds.net/index.php/Thr ... /?pageNo=1
DolbyVisionFTW
Post by DolbyVisionFTW » Sat Dec 04, 2021 11:41 pm
Buzzie wrote: Sat Dec 04, 2021 9:05 pmI use Kodi 19.3 from this site.
Thank you. And do you know if it supports playback of all versions of Dolby Vision (both 4K UHD Blu-ray and streaming platforms) that get discussed in this thread?
fox0910
Post by fox0910 » Sun Dec 05, 2021 9:36 am
DolbyVisionFTW wrote: Sat Dec 04, 2021 11:41 pm
It's depend of your Android TV.
Kodi only sends video to ATV and it play it by hardware.
I.e. my Sony TV (xf9005) can play profile 5 only (from streaming platform).
Buzzie
Post by Buzzie » Sun Dec 05, 2021 12:48 pm
I havent watched much movies lately but the last UHD Bluray Remux movies i watched played fine except for the Audio drop outs but that has been fixed.
What problems do you have?
