Mattl0
#5761 Post by Mattl0 » Fri Nov 26, 2021 8:45 am
RESET_9999 wrote:
Sun Nov 21, 2021 6:53 pm
SteamyUncle wrote:
Sun Nov 21, 2021 5:11 pm
OK. Thanks a lot !
Any way to recode with added black bars maybe ? Pretty simple in general... Do you have any pointers to do it in this DV context?
Because, I am in fact in the same boat regarding these movies...normally all gravy with C9 internal player - I find the DV presentation slightly better on it than on the M9702 in fact - with eARC to HW-Q950T..except, of course, for this effing "file not recognized" issue after one launch.
Are you encountering this issue on the C8 as well with DV/DD+Atmos mp4's ?
Well, I'm not sure if it can be done with profile 5 content but with HDR10 base layer DV (P8) content , yes you can add the black bars with staxrip with some basic script I'm sure you can find somewhere on doom9. still re-encoding though.
I don't have any issue on the C8/plex with DD+ atmos via ARC. But I've been watching mostly TS files and not mp4. I know mp4 is very unstable on the Shield/plex.
Do you think it is better with ts on the x800m2?
#5762 Post by RESET_9999 » Fri Nov 26, 2021 12:07 pm
TS playback is much better than MP4 on the x700, so yes I assume it's the same with the x800m2
Mattl0
#5763 Post by Mattl0 » Fri Nov 26, 2021 10:14 pm
Thanks!I was remuxing all dovi in mp4. It will be much faster directly in ts.
chros
#5764 Post by chros » Sun Nov 28, 2021 11:39 am
quietvoid wrote:
Mon Nov 15, 2021 3:03 pm
You can try this sample: https://mega.nz/file/cY1gEZzQ#eJIRMpZ2X ... PaGtY_35gU
The eagle's beak looks noticeably better in the internal player compared to the Firestick for me.
Next step is probably to try figuring out what's happening and if it can be prevented.
Yes, it looks slightly different via stick4k, but that's what I saw with other contents as well, not sure why.
Was this the 10.000 nits version or the 1000/4000 one?
On a different note, Stacey here mentioned again, that there is a setting (I guess in the RPU) with which the DoVi tonemapping can be turned off, do you know which one?
Here is a calibration pattern sample, that should be like it.
This way I guess we can create calibration samples from hdr10 ones.
quietvoid
#5765 Post by quietvoid » Sun Nov 28, 2021 1:30 pm
That was the 10 000 nits version.
I'm not sure what flags would actually disable tonemapping.
IIRC an empty profile 8 RPU like those created by 'generate' are tonemapping every detail, but usually with a dimmer APL.
We'll probably have to wait for the new disc, unless someone tries to ask Stacey how it works.
Buzzie
#5766 Post by Buzzie » Mon Nov 29, 2021 1:59 pm
Anybody that can help me?
I am trying to accomplish the following :
What i would like to achieve with Dovi tool or any other is to download a WEB-DL from any source, take out the DV metadata and add it to the UHD remux so that those versions have DV too.
What i did so far are the following steps:
c:\Dolby-Vision-Tools\ffmpeg\bin\ffmpeg.exe -i "c:\temp\DV_WEB-DL.mkv" -c:v copy -vbsf hevc_mp4toannexb -f hevc c:\temp\DV.hevc
extracted the video from the UHD and named it HDR10.hevc
c:\Dolby-Vision-Tools\dovi_tool.exe -m 3 extract-rpu c:\temp\DV.hevc
made a edited.json file for the RPU
c:\Dolby-Vision-Tools\dovi_tool.exe editor -i c:\temp\RPU.bin -j c:\temp\edited.json --rpu-out c:\temp\RPU-edited.bin
c:\Dolby-Vision-Tools\dovi_tool.exe inject-rpu -i c:\temp\HDR10.hevc --rpu-in c:\temp\RPU-edited.bin
Lastly copied the HDR10.hevc file to the extracted contents of the UHD and used mkvtoolnix to make a new MKV
This one did not have the DV info.
What am i doing wrong?
Thanks again !
chros
#5767 Post by chros » Mon Nov 29, 2021 3:24 pm
Thanks, so you didn't see anything related in the attached sample?
quietvoid
#5768 Post by quietvoid » Mon Nov 29, 2021 5:44 pm
Am I supposed to check every RPU frame?
There's nothing indicating a change in the video itself. It's just a static patch.
The metadata suggests the same thing.
chros
#5769 Post by chros » Mon Nov 29, 2021 7:46 pm
No, you aren't, at least this is what I thought. Thanks for checking!
comorla45
#5770 Post by comorla45 » Thu Dec 02, 2021 8:57 am
Thanks again !
Yesterday I was playing a bit around with this "hybrid" format and I will describe what I have done. Be aware however, that I lack all knowledge regarding multimedia files, this was just my 4 hour experiment for fun.
1. I got two identical copies of Web-DL Foundation E01, one in MP4 Dolby Vision, second in MKV HDR10 format.
2. I extracted audio using tsMuxeR.
3. I used FFMPEG to extract DV.hevc and HDR10.hevc
4. Using DoVi Tool I extracted RPU from DV.hevc.
5. I injected RPU into HDR10.hevc using DoVi Tool.
6. I muxed all together (HDR10_DV.hevc + audio) into M2TS cointainer.
Why M2TS? My LG OLED will only recognize Dolby Vision in MP4 or M2TS container, not in MKV.
Using this muxed hybrid hdr10-dv +ac3 audio file in M2TS container, I managed to get DV recognized by my LG TV and at the same time fallback to HDR10 on my phone that does not support DV.
I had to use newest night release of tsMuxeR, regular release displayed error when opening hdr10_dv.hevc video stream. This is what MediaInfo says about this hybrid file:
@Buzzie
I can not yet reply to DM, so I will post my commands here:
Command to extract DV.hevc:
ffmpeg.exe -y -i DV_file.mp4 -an -c:v copy -vbsf hevc_mp4toannexb -f hevc DV.hevc
Command to extract RPU:
dovi_tool.exe -m 3 extract-rpu DV.hevc
Command to extract HDR10.hevc:
ffmpeg -i HDR_file.mkv -c:v copy hdr.hevc
Command to inject RPU into HDR10:
dovi_tool.exe inject-rpu -i hdr.hevc --rpu-in RPU.bin -o output.hevc
All files were in the same folder (ffmpeg, dovi tools, mp4, mkv etc) so no paths are specified, just filenames.
Buzzie
#5771 Post by Buzzie » Fri Dec 03, 2021 7:56 am
Thanks again !
@Buzzie
Thanks pal !!
I got it to work.
First it didnt work when i tried to make an MKV......but with m2ts and nightly tsmuxer it worked.
But since i am taking out the DV metadata and add it to MKV Remux i had to use mkvtoolnix but it didnt work.
I was still using an old version so i downloaded the latest version and bam !!
Captain America Civil War in 2160 with Dolby Vision Remux :)
comorla45
#5772 Post by comorla45 » Fri Dec 03, 2021 2:05 pm
Thats great to hear! Can you share more about your setup? Do you play via Plex, from USB or some other method? What kind of TV do you have? Thanks!
In my case I use Plex to stream to my TV and mobile phone.
Buzzie
#5773 Post by Buzzie » Sat Dec 04, 2021 1:26 pm
Sure !
I use Kodi on my Nvidia Shield 2019 Pro to watch on my LG C1 tv
DolbyVisionFTW
#5774 Post by DolbyVisionFTW » Sat Dec 04, 2021 6:22 pm
Which version of kodi do you use that supports Dolby Vision playback?
Thanks.
Buzzie
#5775 Post by Buzzie » Sat Dec 04, 2021 9:05 pm
Thanks.
I use Kodi 19.3 from this site.
Its an altered version of Kodi that installs next to the Google Play Store version so you can easily test it
https://www.kodinerds.net/index.php/Thr ... /?pageNo=1
