Re: Ultimate UHD Drives Flashing Guide Updated 2021
guided updated with new flashing override commands and 2 new drives recommended firmware flashing steps
grexe
Post by grexe »
Just got my Archgon MD-8107S-U3+BU40N(K) from the recommended drives list, which is correclty identified as:
$ makemkvcon f -l
Found 1 drives(s)
00: dev_21:0, /dev/sr0, /dev/sr0
  HL-DT-ST_BD-RE_BU40N_1.01_211712221221_KZZICCG5934
But when trying to flash with the associated firmware from the ultimate pack, I get an error that was also encountered by another user, who had to resort to downgrading using the legacy flash tool, which I'd like to avoid, since this should now be possible the standard way from the updated 2021 guide, right?
$ makemkvcon f -d "dev_21:0" -f sdf.bin rawflash main -i HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Reading input file HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Current Drive ID: HL-DT-ST_BD-RE_BU40N_1.01_211712221221_KZZICCG5934
DEBUG: Code 4280012805 at Mx=Q{%DdK23UWRSK}6/xi^l-6'?wWl*&:121264648
Command produced error code 0x8f1bd005
I'm on Manjaro Pahvo with Linux 5.14.18-1 and for the first time, tried the snap package, since I was missing some compile dependencies I couldn't find right away - but since makemkv works flawlessly, including ripping a bluray, I don't suspect that's the problem.
lidejia wrote: Wed Oct 13, 2021 11:02 am
lidejia wrote: Tue Oct 12, 2021 1:09 pm Hello everyone.
I tried to flash the drive firmware in order to enable LibreDrive, but unfortunately it failed with the following message:
makemkvcon f --all-yes -d /dev/sr0 -v rawflash -i ~/Downloads/mk-firmware-pack-20200720/MK/HL-DT-ST/BH16NS60/HL-DT-ST-BD-RE_BH16NS60-1.02-NM00600-212005081014.bin
Loaded SDF.bin version 0x7e
Reading input file ~/Downloads/mk-firmware-pack-20200720/MK/HL-DT-ST/BH16NS60/HL-DT-ST-BD-RE_BH16NS60-1.02-NM00600-212005081014.bin
Current Drive ID: HL-DT-ST_BD-RE__BH16NS60_1.01_211901041419_KLJJ6OA2118
Write flags NG 05/FF/03
Command produced error code 0x8f05ff03
I tried this on windows and linux, but none of them work. I also tried the GUI tool, but the same error code pop up.
The following is my drive information
OS device name: /dev/sr0
Product: BD-RE BH16NS60
Revision: 1.01
Firmware date: 2119-01-04 14:19
Bus encryption flags: 1F
Highest AACS version: 76
Any ideas on how to solve this issue? Thanks very much.
I was able to flash the firmware after using this legacy flasher: viewtopic.php?f=16&t=18873#p70284
grexe
Post by grexe »
dammit, it *was* the snap - I shouldn't have been so lazy and just install pkg-conf, then compiling worked and with the "native" makemkv, flash worked like a charm with the firmware listed here:
yes
 100% Operation finished
Done successfully
Drive info now shows LibreDrive is happy, too:)
Firmware version: 1.03
kubev
Post by kubev »
Hi, everyone!
I'm pretty sure I've scoured this guide to the extent that I can, but I'm still running into some issues getting my Buffalo BRUHD-PU3-BK working with MakeMKV reliably in general and at all for ripping UHD discs.
Both the Blu-ray and UHD Blu-ray I'm using to test the drive with are brand new and clean.
I have both USB cables plugged in via a USB hub. I don't know what either cable is for, as the instructions for the drive are entirely in Japanese.
It's my understanding that this drive is just a rebranded BU40N, so I've been trying various versions of BU40N firmware with nothing working consistently. The original post suggests using 1.3, but I've tried 1.3 and 1.4 and still have issues.
I'm using SDFtool Flasher v 1.2.3 and firmware for the BU40N from the MK pack. I've tried 1.3 and 1.4.
As far as I can tell, the firmware flashing seems to be successful each time I try it.
FYI, I have two of this same drive, and they're both exhibiting the same issues.
Here's what MakeMKV shows me when no disc is inserted:
OS device name: E:
Manufacturer: BUFFALO
Product: Optical Drive
Revision: 1.04
Serial number: MOFL5JA1052
Firmware date: 2120-05-06 11:42
Firmware version: 1.04
Here's what MakeMKV shows me when I insert a regular Blu-ray disc:
Revision: 1.04
Disc Information
Label: FAR_AND_AWAY_NA
Timestamp: 2013-11-27 10:02:58
Protection: AACS
Data capacity: 38.60 Gb
Disc type: BD-ROM
Number of layers: 2
Oddly, I also sometimes get a bunch of this beforehand:
MakeMKV v1.16.5 win(x64-release) started
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE BUFFALO Optical Drive 1.04 MOFL5JA1052' at offset '786432'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE BUFFALO Optical Drive 1.04 MOFL5JA1052' at offset '815104'
udf: node fe/efe failed!
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE BUFFALO Optical Drive 1.04 MOFL5JA1052' at offset '1114112'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE BUFFALO Optical Drive 1.04 MOFL5JA1052' at offset '851968'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE BUFFALO Optical Drive 1.04 MOFL5JA1052' at offset '897024'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE BUFFALO Optical Drive 1.04 MOFL5JA1052' at offset '792576'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/AACS/MKB_RO.inf' at offset '0'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/AACS/Content000.cer' at offset '0'
Ripping the disc seems to work just fine, though. MakeMKV detects all the titles and pulls them from the disc without issue.
Much of the time, when inserting a UHD disc, MakeMKV claims that there's no disc inserted. Other times, I get something like this:
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE BUFFALO Optical Drive 1.04 MOFL5JA1052' at offset '30466375680'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE BUFFALO Optical Drive 1.04 MOFL5JA1052' at offset '30466439168'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE BUFFALO Optical Drive 1.04 MOFL5JA1052' at offset '655360'
udf: UDF mount: disc not properly formatted or damaged disc (rootdirs failing)
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE BUFFALO Optical Drive 1.04 MOFL5JA1052' at offset '32768'
I have no idea what else to try. Can anyone help, whether it's by suggesting additional troubleshooting or potentially pointing me toward something I've missed?
kubev wrote: Sat Dec 04, 2021 3:17 am Hi, everyone!
OS device name: E:
Revision: 1.04
Revision: 1.04
Disc Information
Protection: AACS
Disc type: BD-ROM
Number of layers: 2
I don't think the drive is getting enough power. You should not use a USB hub unless the hub has it's own power source.
MartyMcNuts wrote: Sat Dec 04, 2021 3:57 am
yeah defiantly power your drive light will be red it needs to be green always
kubev
Post by kubev »
MartyMcNuts wrote: Sat Dec 04, 2021 3:57 am I don't think the drive is getting enough power. You should not use a USB hub unless the hub has it's own power source.
Oh my God...it's totally working. Time to pick up a USB hub with its own power source, I suppose, as my new PC totally doesn't have enough spare USB ports to devote two to this thing all the time. I'll let this thing hog my front USB ports in the meantime, though.
I'm glad I thought to mention the USB hub, and I'm glad you answered so quickly. I was really worried that maybe this drive wouldn't be as reliable as the Asus drive I was using for ripping regular Blu-rays, but it seems to be working now. Thanks!
Billycar11 wrote: Sat Dec 04, 2021 4:07 am yeah defiantly power your drive light will be red it needs to be green always
D'oh. So, that's what that red light on the back meant. Haha. I probably could've figured this out had they included English instructions.
Thanks to both of you!
zittrig
Post by zittrig »
asmcom wrote: Mon Jan 18, 2021 6:47 pm
zittrig wrote: Mon Jan 18, 2021 6:27 pm
zittrig wrote: Mon Jan 11, 2021 9:26 pm .....
Ok, I've changed my way to rip 4K Blu-ray and bought a drive from ASMCOM. So I can sell my drive without opening the enclosure before.
The drive arrived today. It's a BH16NS40 with firmware 1.02mk for WH16NS60.
Now, the first two 4K-BDs are ripped without any problems.
But in the MK-firmware file exists a version 1.03 for WH16NS60 and a 1.05 for BH16NS40 .... could it make sense to change to one of these younger versions? Is there any benefit?
Do not change anything, leave as is.
Kind Regards
Asmcom :mrgreen:
Meanwhile, ripping without any problems. But again here is my question about a newer firmware for a faster ripping 4k discs? The maximum speed I get is about 8x, perhaps 34 MB/s. I need about 35 minutes to rip Turtles Out Of The Shadows for example. Is a booster possible or another faster drive available?
zittrig wrote: Sat Dec 04, 2021 9:47 am
Kind Regards
Asmcom :mrgreen:
No, that's about it. That is the fastest firmware. The norm is around 40-60 mins depending on size of disc.
zittrig
Post by zittrig »
Ok, thank you for this very fast answer. :)
Inferius7809
Post by Inferius7809 »
I can't seem to get any sort of firmware flash to stick on my Buffalo BRUHD-PU3. Whenever I try updating firmware via SDF, it goes through the process, and it says its successful, but MakeMKV still keeps reading out the revision of "BU13". I've tried flashing the firmware through both the Command Line in windows, and previously mentioned SDF. Again, in both times, they say they were successful, but the revision doesn't change. I've also tried the Downgrade Tool, but whenever I try to run it, It comes up with the error "Valid ATAPI Device Cannot Be Found!!! F/W Model is "BD-RE BH14NS40"". Not sure why it's doing that.
I'm kind of at my wit's end here, I'm not entirely certain what I'm doing wrong, and as far as I can tell, this reader should be able to be flashed. It has Unencrypted firmware, and is on the MT1959 Platform. I'm relatively certain the drive was made post 2015 (the Japanese is kinda hard to decipher lol). I just don't know if I'm missing a step, doing something wrong, etc. Thank you for any help.
Inferius7809 wrote: Sat Dec 11, 2021 12:27 am I can't seem to get any sort of firmware flash to stick on my Buffalo BRUHD-PU3. Whenever I try updating firmware via SDF, it goes through the process, and it says its successful, but MakeMKV still keeps reading out the revision of "BU13". I've tried flashing the firmware through both the Command Line in windows, and previously mentioned SDF. Again, in both times, they say they were successful, but the revision doesn't change. I've also tried the Downgrade Tool, but whenever I try to run it, It comes up with the error "Valid ATAPI Device Cannot Be Found!!! F/W Model is "BD-RE BH14NS40"". Not sure why it's doing that.
thats a BU40N use 1.03MK with enc
as the guide says
Inferius7809
Billycar11 wrote: Sat Dec 11, 2021 4:33 am
as the guide says
Hey, thanks for the reply. I was using the unencrypted commands because SDF had said it was unencrypted. But using the encrypted commands worked and I'm in business, thank you! I didn't realize the part of the guide included my firmware as one of the encrypted ones.
MKV.User.Dave
Post by MKV.User.Dave »
Help?
The SDFtool fails to run on win10x64 machine...
Current profile: DVD-ROM
Product: BD-RE WH14NS40
Revision: 1.04
Serial number: KLZJ5F95330
Firmware date: 2119-01-04 13:51
Highest AACS version: 12
Harware support: Yes
Firmware support: No
MKV.User.Dave wrote: Mon Dec 13, 2021 2:03 am Help?
Revision: 1.04
Which version of SDFtool flasher??
