So, I am encountering a very weird issue with a BluRay disc that just came out here in Denmark. The movie is called "Margrete den Første": "https://www.blu-ray.com/movies/Margrete ... ay/298440/", the link is for the Finnish release, but the specifications are still correct.
I can convert the movie to MKV, and watch it on all players with no issues. But if I use the backup feature, then something weird happens.
If try to watch the backup via PowerDVD, it either gives me some random DRM message, and just closes. Or, the movie just loads forever, and nothing happens. I then tried DVDFab Video Player, which just loads for ever, and never starts the movie.
And even weirder is, if I try to burn that backup over to an empty BluRay disc, and put it into my BluRay player, I get this message:
"Copy detected (or a rip tool is running if you are trying to watch this movie on your pc)"
I then tried to make a backup via DVDFab 12, and to my surprise, it could play in both PowerDVD and and DVDFab Video Player, or so I thought.
The menus worked fine, but as soon as I pressed "play", I got that same copy detected message again.
I know that DVDFab has nothing to do with makemkv, but I thought that it could help debug the issue.
I have included the logs from makemkv.
The drive information etc is:
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: KLKKBLF5742
Bus encryption flags: 1F
Highest AACS version: 76
Firmware version: 3.10
Disc Information
Label: MARGRETE DEN FOERSTE
Timestamp: 2021-10-27 11:58:51
Protection: AACS v76
Data capacity: 22.2 Gb
Disc type: BD-ROM
Number of layers: 1
Copy Detected (or a rip tool is running if you are trying to watch this movie on your pc)
- MakeMKV_log.txt
- (151.56 KiB) Downloaded 245 times
Re: Copy Detected (or a rip tool is running if you are trying to watch this movie on your pc)
Debug log started at Fri Dec 03 14:57:31 2021 , written by MakeMKV v1.16.5 win(x64-release)
001005:0000 MakeMKV v1.16.5 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\noahl/MakeMKV_log.txt
001003:0020 DEBUG: Code 0 at ZdroV8Qdn>OkoZ=]P3i`_$c8:121261704
001003:0020 DEBUG: Code 3221225486 at ZdroV8Qdn>OkoZ=]P3i`_$c8:121261727
001003:0020 DEBUG: Code 3221225486 at %?"t/)^<UL<M76n|FU]):213130582
DEBUG: Code 3 at kx/mIn.tna?p(7TlCFJMk\o%:29395310
SDF v07e: ASUS_BW-16D1HT_3.10_211901041014_KLKKBLF5742
001003:0020 DEBUG: Code 0 at FCX0qMEkxy~zx6FI:121269432
001003:0020 DEBUG: Code 0 at FCX0qMEkxy~zx6FI:121269156
No SDF v07e: CyberLnk_VirtualDrive_1.00
SDF id v07e: CyberLnk_VirtualDrive_1.00
001011:0000 Using LibreDrive mode (v06.2 id=0FA242DD4D0B)
005072:0000 Backing up disc into folder "file://C:/Users/noahl/Documents/MARGRETE DEN FOERSTE"
DEBUG: Code 2147483648 at W*;d/f1]i)<B5EJP:121264625
005070:0080 Backup done
005081:0104 Backup done.
001003:0020 DEBUG: Code 3221225664 at FCX0qMEkxy~zx6FI:121267362
DO NOT use PowerDVD to play copies. It is official software and will detect a copy as you have found out. You should use an unofficial player such as VLC or MPC-HC etc. Even DVDFab player should work.noahesbjerg wrote: ↑Fri Dec 03, 2021 3:25 pmHi,
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Disc Information
Disc type: BD-ROM
Number of layers: 1
Actually this message is imbedded into the ripped copy and shows up using any player. The rip I am playing displays this message 20 minutes into the film and lasts for one minute. During the message the audio from the first minute of the film is played. This message only shows up once during the movie. BTW this movie happens to be an MP4 file. The site that has the movie that can also be played online. It's been verified the online version has the same message and misplaced audio from that one minute of the movie. So it is the ripper that RARBG uses. I just noticed that the "missing" part of the movie shows up later into the rip. With the right tools, I could cut and paste the rip and patch the movie if only I knew how. The movie is all there.
So you need help with a playlist?
Yep sounds like user error in picking the wrong title, You picked the one that was to trick you. How many titles are there that are identical in runtime and size.Bill E wrote: ↑Sun Oct 20, 2024 10:28 amActually this message is imbedded into the ripped copy and shows up using any player. The rip I am playing displays this message 20 minutes into the film and lasts for one minute. During the message the audio from the first minute of the film is played. This message only shows up once during the movie. BTW this movie happens to be an MP4 file. The site that has the movie that can also be played online. It's been verified the online version has the same message and misplaced audio from that one minute of the movie. So it is the ripper that RARBG uses. I just noticed that the "missing" part of the movie shows up later into the rip. With the right tools, I could cut and paste the rip and patch the movie if only I knew how. The movie is all there.
