Is there a profile template that grabs all audio, all subtitles and the picture attachment ?
If so, is there a link to it ?
Thank You
Makemkvcon - Profile
Re: Makemkvcon - Profile
Selection rules are no longer set in the profile, and haven't been for some years.
In the GUI, you can set the selection rule in the Preferences->Advanced tab (Expert mode must be enabled).
centuryx476
OK, I understand.
How can I set it for the attachments to be included in the titles using the makemkvcon (CLI) ?
Did you already read Changing default track selection?
To get EVERYTHING, Mike's example of "+sel:all" should work.
centuryx476
Like this ?
makemkvcon64 mkv --param="+sel:all" disc:0 all c:\folder
There are no CLI examples for this. That I can find at least
centuryx476
Well I added it to the GUI and the attachments are now being included in the makemkvcon CLI.
Question is: How do you achieve the same result in lets say a headless box ?
You ever figure out a solution for this?centuryx476 wrote: ↑Thu Dec 09, 2021 11:30 pmWell I added it to the GUI and the attachments are now being included in the makemkvcon CLI.
Hi, I am trying to figure this out as well for a headless box with makemkvcon and no GUI
Answer should be at the following thread...
viewtopic.php?f=10&t=31833
Assuming the moderator approves my post.
