BD or UHD
BD or UHD
Post by Coopervid » Sun Nov 28, 2021 1:46 pm
Hi guys,
I'm not really familiar with all makemkvcon options. I wonder if makemkvcon can be used to find out if the insetrted disc is a BD or UHD (4k) so the result value can be used to start a batch or script accordingly. Just checking the inserted disc without ripping.
Thanks in advance!
EDIT: I found it. If you run makemkvcon -r info >info.txt you will find SINFO: a couple of times. The resolution info is SINFO: x, 0, 19,0: "1920x1080" or "3840x2160".
centuryx476
Re: BD or UHD
Post by centuryx476 » Thu Dec 02, 2021 2:36 am
uuhhh Good Idea.
I shall add this feature to my automated workflow...
