File name completely disregarded
phototrek
Post by phototrek » Wed Dec 01, 2021 4:08 am
Running MakeMKV v1.16.5 darwin(x64-release) on 2019 MacPro Monterey
No matter what I enter into the filename field, it's disregarded and the default track names are used. See movie. Happens with any DVD.
https://www.dropbox.com/s/fntmk9ki7bx0z ... 3.mov?dl=0
Re: File name completely disregarded
Post by Woodstock » Wed Dec 01, 2021 3:14 pm
You are changing the "metadata" name of the file. If you click on the "Name" button to expand it, you'll see a separate entry for the filename.
Changing the metadata name affects what the default filename will be, but it doesn't SET it.
See Changing names with Expert mode enabled for more information.
