Failed to rip Jurasic World: Fallen Kingdom.
MovieLuver
#1 Post by MovieLuver » Tue Nov 30, 2021 5:44 am
Ripped 10 other Blu Ray disks without errors.
I have enabled debugging, but not shown the output here. Let me know if you need to see it.
OS device name: /dev/sr0
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: KLDL5BG1253
Highest AACS version: 66
Firmware version: 1.02
Disc Information
Label: JURASSICWORLDFK_UPB75
Timestamp: 2018-07-25 14:14:16
Protection: AACS v60
Data capacity: 41.19 Gb
Disc type: BD-ROM
Number of layers: 2
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17556719616, attempting to work around
DEBUG: Code 816 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 817 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 818 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 819 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 820 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 821 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 822 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 823 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 824 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 825 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 826 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 827 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 828 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 829 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 830 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 831 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 832 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 833 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 834 at Vbrj\WsD6L/]ib$S0JF.:29394758
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17556719616-17556725760, attempting to work around
DEBUG: Code 835 at Vbrj\WsD6L/]ib$S0JF.:29394758
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17556725760, attempting to work around
DEBUG: Code 836 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 837 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 838 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 839 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 840 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 841 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 842 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 843 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 844 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 845 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 846 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 847 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 848 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 849 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 850 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 851 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 852 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 853 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 854 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 855 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 856 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 857 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 858 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 859 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 860 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 861 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 862 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 863 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 864 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 865 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 866 at Vbrj\WsD6L/]ib$S0JF.:29394758
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17556725760-17556731904, attempting to work around
DEBUG: Code 867 at Vbrj\WsD6L/]ib$S0JF.:29394758
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17556731904, attempting to work around
DEBUG: Code 868 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 869 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 870 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 871 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 872 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 873 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 874 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 875 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 876 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 877 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 878 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 879 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 880 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 881 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 882 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 883 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 884 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 885 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 886 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 887 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 888 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 889 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 890 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 891 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 892 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 893 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 894 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 895 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 896 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 897 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 898 at Vbrj\WsD6L/]ib$S0JF.:29394758
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17556731904-17556738048, attempting to work around
DEBUG: Code 899 at Vbrj\WsD6L/]ib$S0JF.:29394758
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17556738048, attempting to work around
DEBUG: Code 900 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 901 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 902 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 903 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 904 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 905 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 906 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 907 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 908 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 909 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 910 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 911 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 912 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 913 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 914 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 915 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 916 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 917 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 918 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 919 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 920 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 921 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 922 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 923 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 924 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 925 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 926 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 927 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 928 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 929 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 930 at Vbrj\WsD6L/]ib$S0JF.:29394758
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17556738048-17556744192, attempting to work around
DEBUG: Code 931 at Vbrj\WsD6L/]ib$S0JF.:29394758
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17556744192, attempting to work around
DEBUG: Code 932 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 933 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 934 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 935 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 936 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 937 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 938 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 939 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 940 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 941 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 942 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 943 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 944 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 945 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 946 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 947 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 948 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 949 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 950 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 951 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 952 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 953 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 954 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 955 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 956 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 957 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 958 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 959 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 960 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 961 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 962 at Vbrj\WsD6L/]ib$S0JF.:29394758
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17556744192-17556750336, attempting to work around
DEBUG: Code 963 at Vbrj\WsD6L/]ib$S0JF.:29394758
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17556750336, attempting to work around
DEBUG: Code 964 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 965 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 966 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 967 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 968 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 969 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 970 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 971 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 972 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 973 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 974 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 975 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 976 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 977 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 978 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 979 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 980 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 981 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 982 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 983 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 984 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 985 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 986 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 987 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 988 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 989 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 990 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 991 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 992 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 993 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 994 at Vbrj\WsD6L/]ib$S0JF.:29394758
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17556750336-17556756480, attempting to work around
DEBUG: Code 995 at Vbrj\WsD6L/]ib$S0JF.:29394758
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17556756480, attempting to work around
DEBUG: Code 996 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 997 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 998 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 999 at Vbrj\WsD6L/]ib$S0JF.:29394758
DEBUG: Code 0 at Vbrj\WsD6L/]ib$S0JF.:121263291
DEBUG: Code 2 at Vbrj\WsD6L/]ib$S0JF.:121263475
DEBUG: Code 167 at IjaPwj(]14h+k.f<25k(U:213134055
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17557118976, attempting to work around
DEBUG: Code 184 at IjaPwj(]14h+k.f<25k(U:213134055
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17557118976-17557125120, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17557125120, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17557174272, attempting to work around
DEBUG: Code 5 at IjaPwj(]14h+k.f<25k(U:213134055
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17557364736, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17557364736-17557370880, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17557370880, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17557370880-17557377024, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17557377024, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17557377024-17557383168, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17557696512, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17557696512-17557702656, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17557721088, attempting to work around
DEBUG: Code 1 at cKMn~lOCaF~<=dXe``Cn/:121262371
<snip of the same message>
DEBUG: Code 179 at Vbrj\WsD6L/]ib$S0JF.:213132767
DEBUG: Code 332032 at Vbrj\WsD6L/]ib$S0JF.:29395563
DEBUG: Code 162 at IjaPwj(]14h+k.f<25k(U:213134055
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17579053056-17579059200, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17579059200, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17579059200-17579065344, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17579065344, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17579096064, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17579096064-17579102208, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17579409408-17579415552, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17579415552-17579421696, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 17579421696, attempting to work around
DEBUG: Code 19 at Vbrj\WsD6L/]ib$S0JF.:213133250
DEBUG: Code 0 at FFKaS'UgHVbV6Wb{: IZ:213131157
DEBUG: Code 0 at FFKaS'UgHVbV6Wb{: IZ:213131272
DEBUG: Code 8584824 at FFKaS'UgHVbV6Wb{: IZ:121261773
DEBUG: Code 0 at u_dJ[87GV$uCQ\xTv92-x:213129984
DEBUG: Code 0 at IjaPwj(]14h+k.f<25k(U:213137068
DEBUG: Code 1 at F#')`F jfasVEB<E:213132537
Failed to save title 0 to file /home/me/Videos/Jurassic World- Fallen Kingdom/Jurassic World- Fallen Kingdom_t00.mkv
Encountered 47 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
16 titles saved, 1 failed
Re: Failed to rip Jurasic World: Fallen Kingdom.
#2 Post by Billycar11 » Tue Nov 30, 2021 6:00 am
clean the disc
replace disc
clean drive
get BU40N
MovieLuver
#3 Post by MovieLuver » Tue Nov 30, 2021 6:05 pm
A BU40N is better at reading a disc than a WH16NS60/40 ?
#4 Post by Billycar11 » Tue Nov 30, 2021 11:24 pm
Yes
MovieLuver
#5 Post by MovieLuver » Thu Dec 02, 2021 5:57 pm
My WH16NS40 has trouble reading many discs. Nearing 50%. What do you think the read % will be with a BU40N ?
Is there a way to slow down the read on my WH16NS40 so that it reads better ? I don't see read speed in the Preferences window.
Any other tricks to get a drive to read better ?
MovieLuver
#6 Post by MovieLuver » Tue Dec 14, 2021 4:22 am
I updated to the BU40N drive. Same error.
I get errors with both drives on about half of the disks I attempt to rip. These same disks play fine.
Thoughts ?
#7 Post by dcoke22 » Tue Dec 14, 2021 8:59 pm
MakeMKV drive speed control
Did you clean the disc? If so, did you clean it a second time? The Rip Errors post.
Those errors suggest the drive is unable to correctly read the disc. What MakeMKV is trying to do is different than what your blu-ray player is trying to do. The player will just blow past read errors and hope you don't notice. MakeMKV is trying to correctly read all the bits on the disc to make an exact copy.
