makemkvcon said the firmware was updated, but the firmware version didn't change ?
MovieLuver
Post by MovieLuver »
I updated my drive with makemkvcon. It said it updated the firmware, but the firmware version didn't change.
Here is what I did.
Step 1
Download the firmware pack and uncompress it.
Step 2
Download sdf.bin. I found it here: https://makemkv.com/sdf.bin
Step 3 (optional)
Move the desired firmware and sdf.bin into an isolated directory.
Step 4
Open a terminal in the same directory as the firmware and sdf.bin Verify the files are there.
$ ls -al
total 2576
drwxr-xr-x. 1 me me 120 Nov 27 08:07 .
drwxr-xr-x. 1 me me 248 Nov 27 08:07 ..
-rw-rw-r--. 1 me me 2097152 Aug 31 2019 HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
-rw-r--r--. 1 me me 538976 Nov 27 08:06 sdf.bin
Step 5 Find your drive identifier
$ makemkvcon f -l
Found 1 drives(s)
00: dev_21:0, /dev/sr0, /dev/sr0
HL-DT-ST_BD-RE__WH16NS40_1.05_212005061440_KLDL5BG1253
Step 6 Update the drive
]$ makemkvcon f -d'dev_21:0' -f./sdf.bin rawflash main -i HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Reading input file HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Current Drive ID: HL-DT-ST_BD-RE__WH16NS40_1.05_212005061440_KLDL5BG1253
yes
100% Operation finished
Done successfully
However, makemkv says:
OS device name: /dev/sr0
Product: BD-RE WH16NS40
Revision: 1.05
Serial number: KLDL5BG1253
Harware support: Yes
Firmware support: No
Firmware version: 1.05
$ makemkvcon f -l
Found 1 drives(s)
Why didn't the firmware update ?
I ran this as a regular user. Did I need to run it as SU ? I reran it as SU, with the same result.
Re: makemkvcon said the firmware was updated, but the firmware version didn't change ?
I don't see a step where you powered the drive off so it would start running the new firmware. Did you do that? If not, the original firmware is still running.
MovieLuver
I did a reboot, but maybe it wasn't powered down enough. Let me try a complete shutdown.
MovieLuver
I just did a complete shutdown, including removing the power cord. Same outcome. Firmware hasn't changed.
Enc
MovieLuver
Enc ?
BTW, the drive still works.
Thanks for the quick replies.
MovieLuver
Billycar11 wrote:
Sat Nov 27, 2021 3:40 pm
Enc
Enc ?
Edit: I figured it out. I'll update this in a sec.
MovieLuver wrote:
Sat Nov 27, 2021 4:00 pm
Enc
Enc ?
Yes enc read the guide I didn't make it for no reason
MovieLuver
Billycar11 wrote:
Sat Nov 27, 2021 4:10 pm
Enc
Enc ?
I got it flashed using:
makemkvcon f -d'dev_21:0' -f./sdf.bin rawflash main,enc -i HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Which guide ?
I tried using makemkvcon help. It lists:
f <args>
run universal firmware tool
No mention of what the args are. And there is no man page either. Just saying.
Thanks for the help and the tools.
You replace main with enc not add it to it
