yeah in your email 31 mins ago
Re: Ultimate UHD Drives Flashing Guide Updated 2021
I have not received it. Just sent you another email.
We don't know as that firmware has never been seen before. Try it and see what happens.Tober27 wrote: Fri Nov 26, 2021 4:57 amThe old Flasher READ Firmware worked, where it didn't with the newer. WRITE Firmware still did nothing.MartyMcNuts wrote: Fri Nov 26, 2021 4:50 am You could try the old SDFtool Flasher (version 1.2.0) as that doesn't check the drive platform.
"enc?" should not be checked, correct?
The Custom Firmware seemed to fail, email response sent.MartyMcNuts wrote: Fri Nov 26, 2021 5:24 amWe don't know as that firmware has never been seen before. Try it and see what happens.
Checking "enc?" made no difference. START button still did nothing.
Through recommendations from Billy, ran the Asus Flasher and it worked.MartyMcNuts wrote: Fri Nov 26, 2021 5:24 am We don't know as that firmware has never been seen before. Try it and see what happens.
No problems yet.
That's great!Tober27 wrote: Fri Nov 26, 2021 9:44 pmThrough recommendations from Billy, ran the Asus Flasher and it worked.MartyMcNuts wrote: Fri Nov 26, 2021 5:24 am We don't know as that firmware has never been seen before. Try it and see what happens.
No problems yet.
Totally. Thought you could make a note of it in case it comes up again.
Yep, I'm sure Billy will add a note to the guide.Tober27 wrote: Fri Nov 26, 2021 11:21 pmTotally. Thought you could make a note of it in case it comes up again.
there is a situation where if this happens again with encrypted firmware there would be no way to flash the drive.
going to email mike about it before the update
Pioneer has released a new unit BDR-S13J-X, I should receive it in two weeks, I would like to know if this new unit is possible to work with makemkv for UHD ?
https://jpn.pioneer/ja/pcperipherals/bd ... j-x/?ad=pr
Best Regards,
Best Regards,
Unless it contains non-Pioneer drive, the chance is about zero. No Pioneer hardware is currently "UHD Friendly", and there is no firmware available to change that.
so I will never be able to backup my UHD movies with this drive?Woodstock wrote: Mon Nov 29, 2021 7:40 pm Unless it contains non-Pioneer drive, the chance is about zero. No Pioneer hardware is currently "UHD Friendly", and there is no firmware available to change that.
I think I arrived late to this forum
Thanks for reply,
Mike thinks it is possible, but it won't be simple and it won't be soon.
Pioneer drives do have their advantages; USUALLY they're top performers at writing disks, more so that the LG/Asus units.
- Contact:
This is very unusual...MartyMcNuts wrote: Fri Nov 26, 2021 4:08 am It seems that MakeMKV is not recognising your drive's platform as MT1959,
Please do this for me:Tober27 wrote: Fri Nov 26, 2021 4:21 am in SDFTool the full drive is labelled:
HL-DT-ST__BD-RE_BU40N_DN13_211907041426_MO9K6D81503
if that's anything.
sdftool -d HL-DT-ST__BD-RE_BU40N_DN13_211907041426_MO9K6D81503 --info
sdftool -d HL-DT-ST__BD-RE_BU40N_DN13_211907041426_MO9K6D81503 -t mtk19xx dump auto
sadly i don't think they will be able to dump the firmware info as i helped them flash to BU40N 1.03mk.mike admin wrote: Wed Dec 01, 2021 11:14 pmThis is very unusual...MartyMcNuts wrote: Fri Nov 26, 2021 4:08 am It seems that MakeMKV is not recognising your drive's platform as MT1959,
if that's anything.
andCode: Select all
for future reference - "-t" switch forces the tool to select specific "drive logic" payload, ignoring the auto-detect logic. Specifically "-t mtk19xx" forces mtk19xx payload.Code: Select all
but i am able to say they were then able to start coping a UHD disc so it is mt1959.
but thanks again for the override flash info
