whats your makemkv drive info sectionTober27 wrote: Fri Nov 26, 2021 3:30 amYes, the bin file is selected and visible right above "Ready..."
Re: Ultimate UHD Drives Flashing Guide Updated 2021
Tober27
Product: BD-RE BU40N
Revision: DN13
Serial number: MO9K6D81503
Firmware date: 2119-07-04 14:26
Bus encryption flags: 1F
Highest AACS version: 76
i would think it would work unless that case does not support flashing but it just looks like a buffalo rebrand off so it probably supports it.Tober27 wrote: Fri Nov 26, 2021 3:33 amDrive Information
Revision: DN13
your not checking enc right?
It seems that MakeMKV is not recognising your drive's platform as MT1959, cause that should have a green tick next to it. If the drive platform is marked with a red X, then the start button is disabled so that you can't accidently flash a non-compatible drive. I still think that the current firmware is the problem. Never seen it before...Tober27 wrote: Fri Nov 26, 2021 3:23 amSo when I press START it seems nothing happens.Billycar11 wrote: Fri Nov 26, 2021 3:00 am first page BU40N 1.03mk on any BU40N one flash and done get the all you need firmware pack
MT1959 Platform:
Encrypted Firmware:
both have red X
"Ready..." doesn't change.
When you run MakeMKV does it say "Drive Platform MT1959" anywhere on the right hand side?
Tober27
I don't see any Drive Platform information, only the Drive Information posted above.MartyMcNuts wrote: Fri Nov 26, 2021 4:08 am It seems that MakeMKV is not recognising your drive's platform as MT1959, cause that should have a green tick next to it. If the drive platform is marked with a red X, then the start button is disabled so that you can't accidently flash a non-compatible drive. I still think that the current firmware is the problem. Never seen it before...
in SDFTool the full drive is labelled:
HL-DT-ST__BD-RE_BU40N_DN13_211907041426_MO9K6D81503
if that's anything.
well in this case you cant use the sdf tool for now marty will probably fix it soon.
but you can use the cmd to do it or email me for an automated flasher
Tober27
Just sent you an email.Billycar11 wrote: Fri Nov 26, 2021 4:26 am well in this case you cant use the sdf tool for now marty will probably fix it soon.
There's nothing to fix. The tool is working properly. If MakeMKV doesn't recognise the drive as platform MT1959, there's nothing I can do about it. There must be something up with that drive as MakeMKV should also be showing the LibreDrive section (including drive platform)Billycar11 wrote: Fri Nov 26, 2021 4:26 am well in this case you cant use the sdf tool for now marty will probably fix it soon.
You could try the old SDFtool Flasher (version 1.2.0) as that doesn't check the drive platform.Tober27 wrote: Fri Nov 26, 2021 4:21 amI don't see any Drive Platform information, only the Drive Information posted above.MartyMcNuts wrote: Fri Nov 26, 2021 4:08 am It seems that MakeMKV is not recognising your drive's platform as MT1959, cause that should have a green tick next to it. If the drive platform is marked with a red X, then the start button is disabled so that you can't accidently flash a non-compatible drive. I still think that the current firmware is the problem. Never seen it before...
if that's anything.
ok i see no problem, perhaps an override for situations like this with a special combo that you could tell people in these situationsMartyMcNuts wrote: Fri Nov 26, 2021 4:47 amThere's nothing to fix. The tool is working properly. If MakeMKV doesn't recognise the drive as platform MT1959, there's nothing I can do about it.Billycar11 wrote: Fri Nov 26, 2021 4:26 am well in this case you cant use the sdf tool for now marty will probably fix it soon.
Yeah, that's called the old SDFtool Flasher v1.2.0....... LOLBillycar11 wrote: Fri Nov 26, 2021 4:52 amok i see no problem, perhaps an override for situations like this with a special combo that you could tell people in these situationsMartyMcNuts wrote: Fri Nov 26, 2021 4:47 amThere's nothing to fix. The tool is working properly. If MakeMKV doesn't recognise the drive as platform MT1959, there's nothing I can do about it.Billycar11 wrote: Fri Nov 26, 2021 4:26 am well in this case you cant use the sdf tool for now marty will probably fix it soon.
yeah i know the older version but others dont i guess ill put a note in the guideMartyMcNuts wrote: Fri Nov 26, 2021 4:54 am
Yeah, that's called the old SDFtool Flasher v1.2.0....... LOL![]()
Tober27
The old Flasher READ Firmware worked, where it didn't with the newer. WRITE Firmware still did nothing.MartyMcNuts wrote: Fri Nov 26, 2021 4:50 am You could try the old SDFtool Flasher (version 1.2.0) as that doesn't check the drive platform.
"enc?" should not be checked, correct?
i mean i sent you a flasher just use that?Tober27 wrote: Fri Nov 26, 2021 4:57 amThe old Flasher READ Firmware worked, where it didn't with the newer. WRITE Firmware still did nothing.MartyMcNuts wrote: Fri Nov 26, 2021 4:50 am You could try the old SDFtool Flasher (version 1.2.0) as that doesn't check the drive platform.
Tober27
You did? I haven't received it.
