Any other program like BatchmakeMKV?
Ferrett1983
Post by Ferrett1983 » Thu Nov 25, 2021 5:45 pm
Whilst browsing the forums I noticed a program called BatchmakeMKV and it looks exactly what I'm looking for. Only problem is it's no longer been updated from what i see so I'm just wondering if theirs another program like that which is more up to date and is still getting updated?
Re: Any other program like BatchmakeMKV?
Post by d00zah » Thu Nov 25, 2021 8:12 pm
Bear in mind that these tools are usually just front-ends for MakeMKV functionality & MakeMKV is regularly updated. That said, try any one of the several available on this forum & see how you make out.
In the past, I've used MakeMKV-Batch-Converter w/ good results... but the source link has since changed to MakeMKV-Batch-Converter on github. The only problem I ever had was an occasional failed queue entry, which subsequently succeeded when re-queued. YMMV
Ferrett1983
Post by Ferrett1983 » Fri Nov 26, 2021 11:03 am
I like the program and it looks like it will do everything I need but the program fails when a queue of movies are lined up. It will do single movies fine though. Its a shame theirs no more updates
Post by d00zah » Fri Nov 26, 2021 1:20 pm
Kinda spoils the whole 'batch' concept...
Using the version I have installed, I just...
- dragged a folder of .iso files into the tool
- made sure to 'check' each item in the list I want (no 'check all' option) to convert
- 'start' processing the queue
Seems to work as advertised...
Ferrett1983
Post by Ferrett1983 » Fri Nov 26, 2021 2:30 pm
d00zah wrote: Fri Nov 26, 2021 1:20 pm Kinda spoils the whole 'batch' concept...
I'm not sure what the problem could be? I just dragged and dropped folders rather than ISO files and just kept getting the message failed to convert which wasn't ideal. Really wish the program was still being developed as theirs definitely a space for MakeMKV batch software.
Post by d00zah » Fri Nov 26, 2021 2:46 pm
After you drag/drop the folder, did you 'mark' titles in the list to add to the process queue? Seems to work for me??
QueueSel (Small).jpg (37.16 KiB) Viewed 14252 times
Ferrett1983
Post by Ferrett1983 » Fri Nov 26, 2021 3:24 pm
d00zah wrote: Fri Nov 26, 2021 2:46 pm After you drag/drop the folder, did you 'mark' titles in the list to add to the process queue? Seems to work for me??
Basically what I do is add the folders to the queue and then sort out what I'm keeping and what I'm getting rid of and then when I'm finished I tick the first file and that starts converting and then I tick the rest of the files so their ready to remux.
Chetwood
Post by Chetwood » Thu Dec 02, 2021 9:14 pm
MakeMKV Batch Converter does not seem to support special chars like German Umlauts; titles with them will be skipped.
