John Wick 3 Parabellum Amazon 4K Ultra HD + Blu-Ray + Digital
arhame71
Post by arhame71 » Wed Nov 24, 2021 5:41 am
I have just purchased this movie and I have NEVER had one movie give me so many issues on trying to determine which is the correct mpls to use.
The 4K Ultra HD - No issues at all
The Blu-Ray IS the issue.
I have read through post after post here on others experiencing the issue and still have not found a solution.
I have ripped close to, if not over 1,000 of my discs all the way from DVD up to 4K and have never experienced this amount of difficulty.
Typically, I have always just chosen the correct file, selected the video, the audio track I want, and the subtitle track, clicked the Make MKV, and tada, flawless.
For the first time, I have downloaded and ran BDInfo (after reading through the forums) to see if that would assist me in determining which to select. All I am seeing is, what appears to be, a few hundred MPLS files in the upper window, all with the length of 02:10:45 and estimated size of 32.05 GB.
As I randomly click through the various MPLS files, it appears as if 00504.M2TS is always the first and 00517.M2TS is always the last.
Any suggestions on how to determine the correct MPLS playlist file to use?
I have no idea how I have been so lucking going through hundreds and hundreds of discs and have NEVER had this much of an issue.
Thank you for any information you might offer / suggest.
Re: John Wick 3 Parabellum Amazon 4K Ultra HD + Blu-Ray + Digital
Post by dcoke22 » Wed Nov 24, 2021 2:23 pm
Have you read through the John Wick 3 post? viewtopic.php?f=8&t=20362
John Wick 3 is from Lionsgate, which often uses 'playlist obfuscation' to make ripping more complicated.
If you have Java installed, MakeMKV tries to choose the correct movie on discs with all the fake playlists. It isn't always right, but it often is.
arhame71
Post by arhame71 » Wed Nov 24, 2021 7:35 pm
Yes, I did read through the complete post before I posted my issue.
I do have Java installed and MakeMKV did not find the correct playlist.
Post by dcoke22 » Thu Nov 25, 2021 2:43 pm
Some folks posted segment maps in there of what was the correct title for them. Were none of those the right one for you?
In any case, I'm sure you know that if you make a decrypted backup, you can play individual segments (in the BDMV/STREAM folder) with VLC or MPV.
In other places on the forum there's been discussion on how to use Process Monitor or VLC+MakeMKV to find the correct segment map. viewtopic.php?f=6&t=16251
