No Disc. HELP!
Twinflicks
No Disc. HELP!
#1 Post by Twinflicks » Tue Nov 23, 2021 10:26 pm
So I just dl the software. I put in my 4KUHD disc and after a couple of minutes loading it says "No Disc" whats happening? How do I fix this?
Paul
Re: No Disc. HELP!
#2 Post by Woodstock » Wed Nov 24, 2021 1:39 am
Do you have a UHD-capable drive? What you describe is typical for trying to read a UHD disk in a regular Bluray drive.
Twinflicks
Re: No Disc. HELP!
#3 Post by Twinflicks » Wed Nov 24, 2021 1:42 am
I did purchase a external 4KUHD drive and it wouldn't recognize it. Do I need to get an internal UHD drive?
Twinflicks
Re: No Disc. HELP!
#4 Post by Twinflicks » Wed Nov 24, 2021 1:47 am
Re: No Disc. HELP!
#5 Post by Billycar11 » Wed Nov 24, 2021 2:12 am
Twinflicks wrote: Wed Nov 24, 2021 1:47 am Will this work?
https://www.amazon.com/dp/B07CJWRW4W/re ... 0E2SYTYT6E
it will work but needs to be flashed first see guide below but dont pay $40 extra for a cable and screws just get the bare drive and buy that stuff separate
https://smile.amazon.com/LG-Electronics ... 951&sr=8-2
Re: No Disc. HELP!
#6 Post by Woodstock » Wed Nov 24, 2021 2:15 am
That drive is what is called a "UHD Official", and it can play UHD disks with officially licensed software. Hint: your operating system, by itself, is not licensed to read UHD disks, so it will say "No Disk" when it tries. If you're running the cyberlink software listed on that page, it will find the disk and let you play it. But it won't let you rip the disk.
A "UHD Friendly" drive will be able to see the contents of the disk. That drive CAN have its firmware changed to be "UHD Friendly", but that breaks the ability to use it with "official" software.
MakeMKV should tell you about your options when you run it, in the LibreDrive section of the Info window.
More details in this topic at the top of the UHD Drives forum: Ultimate UHD Drives Flashing Guide Updated 2021
Twinflicks
Re: No Disc. HELP!
#7 Post by Twinflicks » Wed Nov 24, 2021 2:18 am
Ok let me tell you what I need it for. I need to get screenshots from 4KUHD movies. I don't need to rip, just a way to play and take some screengrabs. Is there a simpler way to go about this?
Twinflicks
Re: No Disc. HELP!
#8 Post by Twinflicks » Wed Nov 24, 2021 2:26 am
I tried to rip a 4KUHD using the portable UHD drive. It worked until it didn't. It said Libredrive could not open the disc. Is this because the drive is not flashed??? Will it work if flashed.
Re: No Disc. HELP!
#9 Post by dcoke22 » Wed Nov 24, 2021 3:04 am
Generally speaking, MakeMKV needs the optical drive's firmware to be flashed to support LibreDrive to be able to rip a UHD.
UHDs have a more complicated encryption scheme than regular blu-rays. The LibreDrive firmware makes it possible for MakeMKV to bypass a bunch of it and rip the movie. This firmware is available for a select set of drive models; see the aforementioned Ultimate UHD Drives Flashing Guide.
I just tested taking a screen shot of a 4K rip made with MakeMKV using the player MPV on macOS Big Sur (on Intel). It was successful. I also took a screenshot of a movie purchased & downloaded from the iTunes Store and played with Quicktime. As I suspected, the Quicktime window was blacked out. I have never used 'official' UHD playback software (I don't think there's any available for macOS actually) but I suspect you'd end up with blanked out screenshots by going that route. I think your best chance as success is a flashed drive to allow MakeMKV to rip the movie.
As a side note, if you want to make things easy, there are sellers on this board that will sell you a flashed and tested drive. However, with a bit patience and some reading, you should be able to flash your own drive with freely available tools. It's all in the first post of that guide.
Twinflicks
Re: No Disc. HELP!
#10 Post by Twinflicks » Wed Nov 24, 2021 3:08 am
Thanks for the info! I just talked with Billy Clarkson and he told me exactly which drive to get and he'll send me that flash kit. Awesome. This has been driving me nuts the past 2 days. And I finally found the solution. Any other tips?
