Citizen Kane
OtisPresley
Citizen Kane
Sent in the dump for Citizen Kane from The Criterion Collection
OtisPresley
Re: Citizen Kane
This is now confirmed working! Thanks!
GuidedLight
Re: Citizen Kane
I just got the UHD 4K Criterion disk, however it doesn't seem to be recognized/working with MakeMKV.
Is there something I'm missing to make it work?
Re: Citizen Kane
Depends on what errors you have showing in the display window.
GuidedLight
Re: Citizen Kane
This is the error(s) I'm getting - https://i.ibb.co/TvC7t0q/ckerror.png
Sometimes MakeMKV is able to make it further along and capture half the movie before it crashes, but it never is able to finish.
Re: Citizen Kane
The most frequent cause of those errors are navigation problems on the disk, tied back to read errors. If the drive does not report it as a read error, the data returned is inconsistent.
Have you tried cleaning the disk?
lfoust
Re: Citizen Kane
I was able to get this ripped yesterday and this is how all the discs mapped out for me (including bonus features and chapter names): https://thediscdb.com/movie/citizen-kan ... iterion-4k
GuidedLight
Re: Citizen Kane
Fantastic, the disc washing did help!
And yes, that is exactly the same mapping I got. Thank you for sharing!
Ravik
Re: Citizen Kane
The original 4K disc of Citizen Kane was replaced due to a manufacturing error (https://www.criterion.com/current/posts ... 1-replaced), and subsequently there is a different version floating around. I believe the disc I am in possession of is the rerelease version, and its cert does not appear to be logged yet. Just an FYI...
sephirothkefka
Re: Citizen Kane
Only the original Blu-ray was in need of replacement. The 4K is unaffected. It must just be a different variant that hasn't been reported yet.Ravik wrote: Mon Aug 21, 2023 6:00 pm The original 4K disc of Citizen Kane was replaced due to a manufacturing error (https://www.criterion.com/current/posts ... 1-replaced), and subsequently there is a different version floating around. I believe the disc I am in possession of is the rerelease version, and its cert does not appear to be logged yet. Just an FYI...
