LG WH16NS60 checksum is mismatched drive will go to boot mode
drkoontz
#1 Post by drkoontz » Mon Nov 22, 2021 11:53 pm
Can anyone help me with this error when trying to flash : LG WH16NS60 checksum is mismatched drive will go to boot mode.
I followed this guide : viewtopic.php?f=16&t=19634
Drive is UHD Blu-Ray Disk Rewriter
Model : WH16NS60
2021 05 11
ROM VER : 1.03
SVC CODE : NS60
I tried flashing using : BH14NS40_N1.00-A4_patched
With bin :DE_LG WH16NS60_1.00
Thanks,
Re: LG WH16NS60 checksum is mismatched drive will go to boot mode
#2 Post by Billycar11 » Tue Nov 23, 2021 4:19 am
you didnt follow the guide it says flash to wh16ns60 1.02mk
drkoontz
#3 Post by drkoontz » Tue Nov 23, 2021 5:16 am
Thank you for the reply , but I do not see that file to flash . Can you link the download?
I have attached a screen shot of the files I do see after downloading.
DDScreenshot 2021-11-22 211439.jpg (79.98 KiB) Viewed 9435 times
#4 Post by Billycar11 » Tue Nov 23, 2021 2:08 pm
In the all you need firmware pack in the guide linked below
drkoontz
#5 Post by drkoontz » Tue Nov 23, 2021 4:59 pm
Thank you for your response, I have the all you need pack downloaded.
Is this the correct file to use : HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
#6 Post by Billycar11 » Tue Nov 23, 2021 11:52 pm
drkoontz wrote: Tue Nov 23, 2021 4:59 pm Thank you for your response, I have the all you need pack downloaded.
Yes
drkoontz
#7 Post by drkoontz » Wed Nov 24, 2021 12:20 am
Still no luck , I launched the exe as admin with the following results.
#8 Post by Billycar11 » Wed Nov 24, 2021 12:32 am
drkoontz wrote: Wed Nov 24, 2021 12:20 am Still no luck , I launched the exe as admin with the following results.
You don't read the guide at all just buy an automated flasher from me or Marty
