MPC-BE+LAV Filters vs VLC Media Player?
Vaker86
Which one should I use to play .mkv files which are created by Makemkv program? Is there mainly a difference in sound quality (DTS-HD Master Audio) ?
Re: MPC-BE+LAV Filters vs VLC Media Player?
I play MKV files in VLC without any special filters. They usually aren't needed.
For a time, VLC did not do well with certain audio codecs, but that should be fixed by now.
Vaker86
I use a VLC player too. But are there any differences with the audio codecs in these programs? I read somewhere that the LAV filter would play higher quality DTS Master audio tracks. Does any of the free programs support DTS Master audio lossless audio tracks? Or do they use the "Core" track which is not lossless?Woodstock wrote: Sun Nov 21, 2021 3:02 pm I play MKV files in VLC without any special filters. They usually aren't needed.
Quoting from the LAV project page:
The question then becomes which user interface you prefer.
So, really, these are filters to add to MPC to give it the capabilities of VLC, since they're based on the same projects.LAV Filters - ffmpeg based DirectShow Splitter and Decoders
Cool_Kaylee
VLC player, of course.
Vaker86
Ok. I use VLC Media player.
