Final Fantasy: The Spirits Within UHD
Cannikin
Dump sent!
demon
Re: Final Fantasy: The Spirits Within UHD
Just sent one as well. Received the disc today, but apparently nothin' doin' yet.
ApexAftermath
Oh drat. Just sent my own before seeing this thread.
Cannikin
Decoded for me just now!
obiwan88
Hello, may I know how did you achieve that? Thank you very much.
ariela
Not able yet
I will send mine againThe volume key is unknown for this disc - video can't be decrypted
You probably want to read the UHD FAQ at the top of this forum.obiwan88 wrote: Sun Nov 21, 2021 8:23 am Hello, may I know how did you achieve that? Thank you very much.
ApexAftermath
I'm a little confused myself. The user said they were able to decode it, but based on what I am seeing this disc still is waiting for an update to that key DB. Maybe they meant "I was able to dump that file" when they said "decoded" but to most people it seems like they are saying they got the disc to rip.
cslcm
I was able to decode this disc just fine yesterday (UK release)
General
Unique ID : 20545314897796273690695661553111640965 (0xF74E23B554DF7837EF3D3E0C545AB85)
Complete name : <snip>Final Fantasy- The Spirits Within_t01.mkv
Format : Matroska
Format version : Version 2
File size : 45.1 GiB
Duration : 1 h 45 min
Overall bit rate mode : Variable
Overall bit rate : 61.0 Mb/s
Movie name : Final Fantasy: The Spirits Within
Encoded date : UTC 2021-11-22 14:24:19
Writing application : MakeMKV v1.16.5 win(x64-release)
Writing library : libmakemkv v1.16.5 (1.3.10/1.5.2) win(x64-release)
Video
ID in the original source medium : 4113 (0x1011)
Format : HEVC
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 55.5 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.279
Stream size : 41.0 GiB (91%)
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display color primaries : BT.2020
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1245 cd/m2
Maximum Frame-Average Light Level : 601 cd/m2
Original source medium : Blu-ray
Audio #1
ID in the original source medium : 4352 (0x1100)
Format : MLP FBA 16-ch
Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Codec ID : A_TRUEHD
Bit rate mode : Variable
Bit rate : 4 847 kb/s
Maximum bit rate : 7 965 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 1 200.000 FPS (40 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Stream size : 3.59 GiB (8%)
Title : Surround 7.1
Language : English
Default : Yes
Forced : No
Number of dynamic objects : 11
Bed channel count : 1 channel
Bed channel configuration : LFE
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 485 MiB (1%)
Title : Surround 5.1
Language : English
Service kind : Complete Main
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 01
00:07:01.254 : en:Chapter 02
00:11:05.331 : en:Chapter 03
00:17:28.130 : en:Chapter 04
00:25:38.036 : en:Chapter 05
00:30:51.432 : en:Chapter 06
00:35:21.035 : en:Chapter 07
00:42:31.882 : en:Chapter 08
00:48:15.893 : en:Chapter 09
00:54:34.396 : en:Chapter 10
00:59:28.648 : en:Chapter 11
01:09:53.022 : en:Chapter 12
01:13:35.953 : en:Chapter 13
01:17:29.853 : en:Chapter 14
01:24:05.874 : en:Chapter 15
01:32:18.658 : en:Chapter 16
Cannikin
Yep I was able to rip to an MKV. You might want to restart MakeMKV if you're not pulling the latest keys list!ApexAftermath wrote: Mon Nov 22, 2021 5:18 am I'm a little confused myself. The user said they were able to decode it, but based on what I am seeing this disc still is waiting for an update to that key DB. Maybe they meant "I was able to dump that file" when they said "decoded" but to most people it seems like they are saying they got the disc to rip.
