MPC-BE+LAV Filters vs VLC Media Player?
Vaker86
Post by Vaker86 »
Which one should I use to play .mkv files which are created by Makemkv program? Is there mainly a difference in sound quality (DTS-HD Master Audio) ?
Re: MPC-BE+LAV Filters vs VLC Media Player?
I play MKV files in VLC without any special filters. They usually aren't needed.
For a time, VLC did not do well with certain audio codecs, but that should be fixed by now.
Vaker86
Post by Vaker86 »
Woodstock wrote:
Sun Nov 21, 2021 3:02 pm
I use a VLC player too. But are there any differences with the audio codecs in these programs? I read somewhere that the LAV filter would play higher quality DTS Master audio tracks. Does any of the free programs support DTS Master audio lossless audio tracks? Or do they use the "Core" track which is not lossless?
Quoting from the LAV project page:
LAV Filters - ffmpeg based DirectShow Splitter and Decoders
So, really, these are filters to add to MPC to give it the capabilities of VLC, since they're based on the same projects.
The question then becomes which user interface you prefer.
Cool_Kaylee
Post by Cool_Kaylee »
VLC player, of course.
Vaker86
Post by Vaker86 »
Ok. I use VLC Media player.
