Problem with MakeMKV 1.16.5 for Windows with LibreDrive
I bought Make MKV from 1.16.4 and recently I upgrade to 1.16.5 since then I have problem to rip disc regardless Bluray or UHD, always show fail to open file, can anyone help on this issue? Thanks in advance.
Re: Problem with MakeMKV 1.16.5 for Windows with LibreDrive
Examples of the errors you're getting would help. "Failed to open" can happen if your minimum video time exceeds the longest video on the disk, for example.
Here is the message I received.
MakeMKV v1.16.5 win(x64-release) started
Using LibreDrive mode (v06.2 id=FA108BB7DA63)
Saved AACS dump file as G:/4K UHD 2160p/MKB20_v72_Fast_and_Furious_Presents-_Hobbs_and_Shaw_5077.tgz
Send the .tgz file that was created to svq@makemkv.com so that a key can be generated for it.Saved AACS dump file as G:/4K UHD 2160p/MKB20_v72_Fast_and_Furious_Presents-_Hobbs_and_Shaw_5077.tgz
You'll want to become familiar with the contents of the UHD FAQ, now that you're wandering into the world of UHD.
Thank you so much for the help, will send the .tgz file to svq@makemkv.com. Thanks again.
