I have some 4K UHD backup images (decrypted). How can I tell if the HDR is Dolby Vision? For example, this one says its Dolby Vision and this is what I see in MediaInfo on the biggest stream file. I was maybe expecting to see Dolby Vision on the "HDR format" line.
How to tell if UHD backup is Dolby Vision
plutoscarab
Re: How to tell if UHD backup is Dolby Vision
Are you sure that file has DV? How old is your MediaInfo version? What version of MakeMKV did you use to create the MKV?plutoscarab wrote: Wed Nov 17, 2021 10:52 pm I have some 4K UHD backup images (decrypted). How can I tell if the HDR is Dolby Vision? For example, this one says its Dolby Vision and this is what I see in MediaInfo on the biggest stream file. I was maybe expecting to see Dolby Vision on the "HDR format" line.
It should look more like this:
If you mean m2ts file, for DV, there should be a secondary 1080p track within the main m2ts file. This is the DV layer.
ArArdin
If you mean images as in ISO's or UHD-BD folder structure, the m2ts and the playlists that refer to it will show 2 videostreams in MediaInfo.
Where the big 3840x2160 is the baselayer.
And the second video is 1920x1080 enhancement layer, being MEL or FEL.
Also when importing a UHDBD or mkv containing Dolby Vision, MakeMKV will tell you.
plutoscarab
Oh, I see! Yes, there's a 1080p stream of video in the same m2ts. Thank you both.
plutoscarab
MartyMcNuts, what is your image from? I'm not seeing Dolby Vision in MediaInfo which is windows version 21.09. This is a backup folder structure created from MakeMKV 1.16.5 and I was looking at a single m2ts file.
It is from the DV MKV file created using MakeMKV.plutoscarab wrote: Fri Nov 19, 2021 6:26 pm MartyMcNuts, what is your image from? I'm not seeing Dolby Vision in MediaInfo which is windows version 21.09. This is a backup folder structure created from MakeMKV 1.16.5 and I was looking at a single m2ts file.
lordvader
I thought I'll ask the question here, rather than create a new thread.
I've ripped some UHDs (backup, not to mkv), and I notice that media info doesn't mention Dolby Vision in the m2ts file:
However, if I take that backup, and use makemkv to create an mkv, media info does report Dolby Vision:
Is the minimal metadata on the m2ts file to be expected?
General
Complete name : C:\Video\backup\Ready Player One (2018)\BDMV\STREAM\00014.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 79.5 GiB
Duration : 2 h 19 min
Overall bit rate mode : Variable
Overall bit rate : 81.3 Mb/s
Maximum Overall bit rate : 109 Mb/s
Video #1
Menu ID : 1 (0x1)
Format : HEVC
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : 36
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display color primaries : BT.2020
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 725 cd/m2
Maximum Frame-Average Light Level : 162 cd/m2
Video #2
Menu ID : 1 (0x1)
Format : HEVC
Codec ID : 36
Width : 1 920 pixels
Height : 1 080 pixels
Color space : YUV
Bit depth : 10 bits
General
Unique ID : 308528094891246814808916124328690516446 (0xE81C59838D68304C795BACA3001101DE)
Complete name : C:\Video\Ready Player One\Ready Player One_t02.mkv
Format : Matroska
Format version : Version 2
File size : 77.4 GiB
Overall bit rate : 79.1 Mb/s
Movie name : Ready Player One
Encoded date : UTC 2022-02-10 23:30:38
Writing application : MakeMKV v1.16.5 win(x64-release)
Writing library : libmakemkv v1.16.5 (1.3.10/1.5.2) win(x64-release)
Video
ID in the original source medium : 4113 (0x1011)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 63.0 Mb/s
Frame rate mode : Constant
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.317
Stream size : 61.6 GiB (80%)
Language : English
Default : No
Forced : No
Original source medium : Blu-ray
The second video track (the 1080p one) is the DV metadata track.lordvader wrote: Fri Feb 11, 2022 6:51 am I thought I'll ask the question here, rather than create a new thread.
I've ripped some UHDs (backup, not to mkv), and I notice that media info doesn't mention Dolby Vision in the m2ts file:However, if I take that backup, and use makemkv to create an mkv, media info does report Dolby Vision:Code: Select all
General ID : 0 (0x0) Complete name : C:\Video\backup\Ready Player One (2018)\BDMV\STREAM\00014.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 79.5 GiB Duration : 2 h 19 min Overall bit rate mode : Variable Overall bit rate : 81.3 Mb/s Maximum Overall bit rate : 109 Mb/s Video #1 ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : 36 Duration : 2 h 19 min Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : BT.2020 Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2 Maximum Content Light Level : 725 cd/m2 Maximum Frame-Average Light Level : 162 cd/m2 Video #2 ID : 4117 (0x1015) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : 36 Duration : 2 h 19 min Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : BT.2020 Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2Is the minimal metadata on the m2ts file to be expected?Code: Select all
General Unique ID : 308528094891246814808916124328690516446 (0xE81C59838D68304C795BACA3001101DE) Complete name : C:\Video\Ready Player One\Ready Player One_t02.mkv Format : Matroska Format version : Version 2 File size : 77.4 GiB Duration : 2 h 19 min Overall bit rate mode : Variable Overall bit rate : 79.1 Mb/s Movie name : Ready Player One Encoded date : UTC 2022-02-10 23:30:38 Writing application : MakeMKV v1.16.5 win(x64-release) Writing library : libmakemkv v1.16.5 (1.3.10/1.5.2) win(x64-release) Video ID : 1 ID in the original source medium : 4113 (0x1011) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible Codec ID : V_MPEGH/ISO/HEVC Duration : 2 h 19 min Bit rate : 63.0 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.317 Stream size : 61.6 GiB (80%) Language : English Default : No Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : BT.2020 Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2 Maximum Content Light Level : 725 cd/m2 Maximum Frame-Average Light Level : 162 cd/m2 Original source medium : Blu-ray
lordvader
Figured that - but there's no metadata that mentions Dolby Vision - so how can a player know?
