Getting A Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading On Two Movies
Jedirapper
#1 Post by Jedirapper » Wed Sep 23, 2020 6:39 am
I've been ripping my collection lately but i have hit a snag, both HP7 and Gran Turino fail to rip the actual movie, extras are fine but the movie fails each time.
Here's the log for reference:
File 00122.mpls was added as title #0
File 00008.mpls was added as title #1
File 00100.mpls was added as title #2
File 00011.m2ts was added as title #3
File 00005.m2ts was added as title #4
File 00002.m2ts was added as title #5
File 00009.m2ts was added as title #6
File 00010.m2ts was added as title #7
Title #00014.m2ts has length of 7 seconds which is less than minimum title length of 10 seconds and was therefore skipped
File 00022.m2ts was added as title #8
File 00003.m2ts was added as title #9
File 00000.m2ts was added as title #10
Title #00026.m2ts has length of 5 seconds which is less than minimum title length of 10 seconds and was therefore skipped
Saving 1 titles into directory E:/Ripped/Gran Torino/Movie
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00004.m2ts' at offset '14323740672'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '14323740672'
Failed to save title 2 to file E:/Ripped/Gran Torino/Movie/Gran Torino_t02.mkv
Encountered 11 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
I read it might be the disc, but for both discs to have the same issues is weird.
If anyone has any answers then i'll greatly appricate it.
Re: Getting A Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading On Two Movies
#2 Post by Woodstock » Wed Sep 23, 2020 12:18 pm
Guessing from your log that you're using an external USB-powered drive. It reaches a part of the movie where it can read faster, then runs out of USB power and shuts down.
Make sure the drive is plugged into a FULLY POWERED USB port (not a hub, unless it has its own power supply), and try the rip again.
Jedirapper
#3 Post by Jedirapper » Wed Sep 23, 2020 8:58 pm
Woodstock wrote: Wed Sep 23, 2020 12:18 pm Guessing from your log that you're using an external USB-powered drive. It reaches a part of the movie where it can read faster, then runs out of USB power and shuts down.
I unplugged and plugged into another port but i get a similar error:
MakeMKV v1.15.2 win(x64-release) started
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00004.m2ts' at offset '14320465920'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '14320465920'
I ripped another movie as a test afterwards and it worked with no errors
Not_a_Squirrel
#4 Post by Not_a_Squirrel » Mon Sep 28, 2020 9:09 pm
Im getting this with a hard wired internal blueray drive, I think the issues is the disk rather than the drive.
Title #1 was added (26 cell(s), 1:32:29)
Title #2 has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 was added (1 cell(s), 0:07:15)
Title #4 was added (1 cell(s), 0:07:15)
Title #5 was added (1 cell(s), 0:10:19)
Title #6 was added (1 cell(s), 0:05:47)
Title #7 was added (1 cell(s), 0:05:30)
Title #8 was added (1 cell(s), 0:03:39)
Title #9 was added (1 cell(s), 0:03:55)
Title #10 has length of 66 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10/1 has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10/2 has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Fake cells occupy 76% of the title - assuming fake title
Title #11/1 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/3 has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/4 has length of 106 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/5 has length of 104 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12/2 has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12/3 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12/4 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12/5 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12/6 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12/7 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12/8 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12/9 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12/10 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12/11 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12/12 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #13 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #14 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #15 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 2-20 were skipped due to cell commands (structure protection?)
Jumped to cell 21 from cell 21 due to cell commands (structure protection?)
Loop detected. Possibly due to unknown structure protection.
Fake cells occupy 97% of the title - assuming fake title
Title #16/1 has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Fake cells occupy 93% of the title - assuming fake title
Title #17/1 has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #17/2 has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #18 has length of 81 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #19 has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #20 has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #21 has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #22 has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #23 was added (2 cell(s), 0:02:07)
Title #24 has length of 119 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #25 has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #26 was added (5 cell(s), 0:04:38)
Subtitle stream #3 is identical to stream #2 and was skipped
Subtitle stream #4 is identical to stream #2 and was skipped
Saving 1 titles into directory F:/Video/SCOOBY DOO 2 MONSTERS UNLEASHED
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading 'BD-ROM HL-DT-ST BDDVDRW CH08LS10 1.00' at offset '1536514048'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '1536514048'
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading 'BD-ROM HL-DT-ST BDDVDRW CH08LS10 1.00' at offset '1536841728'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '1536841728'
Failed to save title 0 to file F:/Video/SCOOBY DOO 2 MONSTERS UNLEASHED/SCOOBY DOO 2 MONSTERS UNLEASHED_t00.mkv
Encountered 26 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
Jim Subzero
#5 Post by Jim Subzero » Wed Nov 17, 2021 10:16 pm
Same problem with two different dvds of the same film
#6 Post by dcoke22 » Fri Nov 19, 2021 2:42 pm
