How do I Uninstall DASPI?
Cavalicious
Post by Cavalicious » Wed Feb 23, 2011 2:19 pm
I seem to be having issues since installing DASPI 1.2. In an effort to troubleshoot, I would like to be able to uninstall DASPI. I also noticed that when reading Bluray Discs, that I am capped to 8.8 MB/s or 2.0x. Below is a log when I attempted to rip Star Trek [2009].
Debug log started at Wed Feb 23 04:55:30 2011 , written by MakeMKV v1.6.5 darwin(x86-release)
001005:0000 MakeMKV v1.6.5 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/Cavalicious/MakeMKV_log.txt
002014:0000 Optical drive "DVD+R-DL OPTIARC DVD RW AD-5680H 3AHB" opened in DASPI mode.
002014:0000 Optical drive "BD-RE HL-DT-ST BD-RE  BE08LU20 2.00" opened in DASPI mode.
DISCID=D7F4F568700EE843F32724E9A8295C1285D8450D
003307:0000 File 01000.mpls was added as title #0
003307:0000 File 01001.mpls was added as title #1
003307:0000 File 00000.mpls was added as title #2
003025:0000 Title #00009.mpls has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00012.m2ts was added as title #3
003307:0000 File 00013.m2ts was added as title #4
003025:0000 Title #00014.m2ts has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00015.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01006.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01007.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00011.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory /Volumes/Rips/Star_Trek_Disc_1
001003:0020 DEBUG: Code 1073741829 at 5EoF-:3&s(@1kIfx:29393723
001003:0020 DEBUG: Code 2 at +>@PH894}5 iZK1(:213136562
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '11823740928'
002003:0000 Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '11927353344'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '11937705984'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '11941312512'
002003:0000 Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '11941576704'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '11958939648'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '11960254464'
002003:0000 Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '11963332608'
002003:0000 Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '11963854848'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '11963854848'
001003:0020 DEBUG: Code 0 at #;T"M"((KWQ(BN@0+&DY:29394298
001003:0020 DEBUG: Code 0 at Jv=}O/f18Nlqc%&i6<I=:121261681
001003:0020 DEBUG: Code 0 at #;T"M"((KWQ(BN@0+&DY:29394183
001003:0020 DEBUG: Code 5841726 at #;T"M"((KWQ(BN@0+&DY:29393309
001003:0020 DEBUG: Code 0 at luo#3Eb+D*r/#@J397H>s:29397449
005003:0000 Failed to save title 2 to file /Volumes/Rips/Star_Trek_Disc_1/title02.mkv
005004:0080 0 titles saved, 1 failed
Romansh
Re: How do I Uninstall DASPI?
Post by Romansh » Wed Feb 23, 2011 3:06 pm
brian163 offered a suggestion here: http://www.makemkv.com/forum2/viewtopic ... 894#p10894
Disable DASPI:
sudo kextunload /System/Library/Extensions/daspi.kext
Enable DASPI:
sudo kextload /System/Library/Extensions/daspi.kext
I'm not sure whether moving the extension after unloading it is overkill or not.
Cavalicious
Post by Cavalicious » Wed Feb 23, 2011 4:57 pm
Thanks, I'll try unloading. I'll see if Mike sees anything in the log as to why the rip fails.
Post by mike admin » Thu Feb 24, 2011 10:15 am
Did this disc work without DASPI? It looks like a physically damaged disc, please see http://www.makemkv.com/faq/item/7/catid/6
Cavalicious
Post by Cavalicious » Thu Feb 24, 2011 6:26 pm
I did try the BD after unloading DASPI and deleting the file. Failure still happen (which I guess would confirm a damage disc). But I did notice that I was getting better read speeds through OS access.
