How to tell if UHD backup is Dolby Vision
plutoscarab
#1 Post by plutoscarab » Wed Nov 17, 2021 10:52 pm
I have some 4K UHD backup images (decrypted). How can I tell if the HDR is Dolby Vision? For example, this one says its Dolby Vision and this is what I see in MediaInfo on the biggest stream file. I was maybe expecting to see Dolby Vision on the "HDR format" line.
Re: How to tell if UHD backup is Dolby Vision
#2 Post by MartyMcNuts » Thu Nov 18, 2021 1:22 am
plutoscarab wrote: Wed Nov 17, 2021 10:52 pm I have some 4K UHD backup images (decrypted). How can I tell if the HDR is Dolby Vision? For example, this one says its Dolby Vision and this is what I see in MediaInfo on the biggest stream file. I was maybe expecting to see Dolby Vision on the "HDR format" line.
Are you sure that file has DV? How old is your MediaInfo version? What version of MakeMKV did you use to create the MKV?
It should look more like this:
If you mean m2ts file, for DV, there should be a secondary 1080p track within the main m2ts file. This is the DV layer.
ArArdin
#3 Post by ArArdin » Thu Nov 18, 2021 3:15 am
If you mean images as in ISO's or UHD-BD folder structure, the m2ts and the playlists that refer to it will show 2 videostreams in MediaInfo.
Where the big 3840x2160 is the baselayer.
And the second video is 1920x1080 enhancement layer, being MEL or FEL.
Also when importing a UHDBD or mkv containing Dolby Vision, MakeMKV will tell you.
plutoscarab
#4 Post by plutoscarab » Fri Nov 19, 2021 6:19 pm
Oh, I see! Yes, there's a 1080p stream of video in the same m2ts. Thank you both.
plutoscarab
#5 Post by plutoscarab » Fri Nov 19, 2021 6:26 pm
MartyMcNuts, what is your image from? I'm not seeing Dolby Vision in MediaInfo which is windows version 21.09. This is a backup folder structure created from MakeMKV 1.16.5 and I was looking at a single m2ts file.
#6 Post by MartyMcNuts » Fri Nov 19, 2021 10:37 pm
plutoscarab wrote: Fri Nov 19, 2021 6:26 pm MartyMcNuts, what is your image from? I'm not seeing Dolby Vision in MediaInfo which is windows version 21.09. This is a backup folder structure created from MakeMKV 1.16.5 and I was looking at a single m2ts file.
It is from the DV MKV file created using MakeMKV.
lordvader
#7 Post by lordvader » Fri Feb 11, 2022 6:51 am
I thought I'll ask the question here, rather than create a new thread.
I've ripped some UHDs (backup, not to mkv), and I notice that media info doesn't mention Dolby Vision in the m2ts file:
General
Complete name                            : C:\Video\backup\Ready Player One (2018)\BDMV\STREAM\00014.m2ts
Format                                   : BDAV
Format/Info                              : Blu-ray Video
File size                                : 79.5 GiB
Duration                                 : 2 h 19 min
Overall bit rate                         : 81.3 Mb/s
Maximum Overall bit rate                 : 109 Mb/s
Video #1
HDR format                               : SMPTE ST 2086, HDR10 compatible
Mastering display color primaries        : BT.2020
Maximum Content Light Level              : 725 cd/m2
Maximum Frame-Average Light Level        : 162 cd/m2
Video #2
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
However, if I take that backup, and use makemkv to create an mkv, media info does report Dolby Vision:
General
Unique ID                                : 308528094891246814808916124328690516446 (0xE81C59838D68304C795BACA3001101DE)
Complete name                            : C:\Video\Ready Player One\Ready Player One_t02.mkv
Format version                           : Version 2
File size                                : 77.4 GiB
Overall bit rate                         : 79.1 Mb/s
Movie name                               : Ready Player One
Encoded date                             : UTC 2022-02-10 23:30:38
Writing application                      : MakeMKV v1.16.5 win(x64-release)
Writing library                          : libmakemkv v1.16.5 (1.3.10/1.5.2) win(x64-release)
Video
ID in the original source medium         : 4113 (0x1011)
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Bit rate                                 : 63.0 Mb/s
Bits/(Pixel*Frame)                       : 0.317
Stream size                              : 61.6 GiB (80%)
Is the minimal metadata on the m2ts file to be expected?
#8 Post by MartyMcNuts » Fri Feb 11, 2022 7:40 am
lordvader wrote: Fri Feb 11, 2022 6:51 am I thought I'll ask the question here, rather than create a new thread.
General
Format                                   : BDAV
Video #1
Video #2
General
Video
The second video track (the 1080p one) is the DV metadata track.
lordvader
#9 Post by lordvader » Fri Feb 11, 2022 9:00 am
Figured that - but there's no metadata that mentions Dolby Vision - so how can a player know?
