I run Linux machines. I don't have access to a Windows PC to flash my WH16NS40. Can I flash it using the GUI SDF tool under wine in Linux ?
Or, is there a command line version of the SDF tool that I could use to flash my drive from a DOS disk ?
Will the GUI SDF tool work properly under wine in Linux ?
Re: Will the GUI SDF tool work properly under wine in Linux ?
You can flash drives on macOS from the command line. Presumably things work similarly on Linux.
viewtopic.php?f=4&t=23129
Thank you. That was very helpful.
Update
The GUI SDF tool will start under wine in Linux. But the drive doesn't list in the drop down box. There is probably a way to get it to, but too much hassle for me. So I reverted to the command line.
Step 1
Download the firmware pack and uncompress it.
Step 2
Download sdf.bin. I found it here: https://makemkv.com/sdf.bin
Step 3 (optional)
Move the desired firmware and sdf.bin into an isolated directory.
Step 4
Open a terminal in the same directory as the firmware and sdf.bin Verify the files are there.
$ ls -al
total 2576
drwxr-xr-x. 1 me me 120 Nov 27 08:07 .
drwxr-xr-x. 1 me me 248 Nov 27 08:07 ..
-rw-rw-r--. 1 me me 2097152 Aug 31 2019 HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
-rw-r--r--. 1 me me 538976 Nov 27 08:06 sdf.bin
Step 5 Find your drive identifier
$ makemkvcon f -l
Found 1 drives(s)
00: dev_21:0, /dev/sr0, /dev/sr0
HL-DT-ST_BD-RE__WH16NS40_1.05_212005061440_KLDL5BG1253
Step 6 Update the drive
]$ makemkvcon f -d'dev_21:0' -f./sdf.bin rawflash main,enc -i HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Reading input file HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Current Drive ID: HL-DT-ST_BD-RE__WH16NS40_1.05_212005061440_KLDL5BG1253
yes
100% Operation finished
Done successfully
Step 7
Reboot to power down the drive. It won't read and use the new firmware until it restarts.
Step 8
Verify the drive has been updated in MakeMKV or with makemkvcon f -l.
$ makemkvcon f -l
Found 1 drives(s)
HL-DT-ST_BD-RE__WH16NS60_1.02_211810291936_KLDL5BG1253
Note: the the first time I ran the firmware update, makemkvcon gave me the same output, ie success, but the firmware version didn't change. The problem was I used "rawflash main" instead of "rawflash main,enc" because the firmware is encoded. I reran it with "main,enc" and then it worked.
Note 2: makemkvcon gets installed with the makemkv package. You don't have to install it separately.
I hope this helps someone.
Step 1
Step 2
Step 3 (optional)
Step 4
$ ls -al
total 2576
$ makemkvcon f -l
Found 1 drives(s)
yes
Done successfully
Step 7
Step 8
$ makemkvcon f -l
Found 1 drives(s)
