US Retail
Title information
Source file name: 00467.mpls
Duration: 1:52:00
Chapters count: 16
Segment count: 15
Segment map: 502,508,514,512,509,515,501,511,506,505,513,510,503,507,504
File name: The Courier_t168.mkv
The Courier
Crtguy
Re: The Courier
What about Netflix? I get 00858.mpls with Java.
el_pollo_hermano
Re: The Courier
So is this a new technique to stop piracy? I found 00109.MPLS to also give the same segment order. Annoying.
Re: The Courier
Not new.Been around for a few years. If you don't buy Lionsgate disks, you won't see it.
Steveredrum
Re: The Courier
hvnphoto wrote: Wed Jun 02, 2021 3:18 pm US Retail
Title information
Duration: 1:52:00
Chapters count: 16
Segment count: 15
Works great for me again thanks for all your previous Playlists please
keep up the good work
Turtle
Re: The Courier
Did you figure out what the Netflix one was?
kevonator
Re: The Courier
I have the Netflix version. Java saying the same as retail. Only thing different is the title:
The Courier-FPL_MainFeature_t01
The t01 is different, but the only difference.
Can anybody verify if this is correct?
Re: The Courier
The title is generated by MakeMKV and is not guaranteed to be the same on different computers. The .mpls and segment map, however, will (almost) always be the same.
So, if you've got a title with the same segment map, then you're good to go.
If you want to be doubly sure, make a decrypted backup (https://makemkv.com/faq/item/4) of the disc first, then make a .mkv file from the backup. Don't delete the backup until you watch the movie and verify it is correct. If you accidentally got the wrong playlist, you can easily make a new .mkv file from the backup, no optical disc needed.
casa8899
Re: The Courier
Pls advise, since found the correct playlist of 467, what shall we do with this? To rename this 467 to which list in order to make the BD play rightfully, thanks
Re: The Courier
Your question is rather disjointed. This is not about making the disk "play rightfully", it's about which play list to have MakeMKV extract from the disk. You can uncheck the other titles, as they are fake.
casa8899
Re: The Courier
Woodstock wrote: Tue Nov 16, 2021 1:53 pm Your question is rather disjointed. This is not about making the disk "play rightfully", it's about which play list to have MakeMKV extract from the disk. You can uncheck the other titles, as they are fake.
Thanks Woodstock, i understand the concept and idea here, what i am trying to get is for Bluray ISO (not the MKV extracted) to play normal, since have found this 467 is the correct playlist, how does we make the ISO file to play ? Pls advice! Thanks
Re: The Courier
Cannot help with that. The menu on the disk is going to decide you are playing a non-genuine copy and not let it work. You will have to modify the menu system to bypass that behavior.
casa8899
Re: The Courier
Thanks Woodstock, any idea or recommend the application/software to modify the menu system?Woodstock wrote: Wed Nov 17, 2021 1:39 am Cannot help with that. The menu on the disk is going to decide you are playing a non-genuine copy and not let it work. You will have to modify the menu system to bypass that behavior.
