How do I get a replacement for damaged discs?
grandpixel
#1 Post by grandpixel » Wed Nov 17, 2021 2:07 am
So I ripped my collection of about 600 movies, and ended up with about 10 that wouldn't rip because of scratches or otherwise damaged discs. How should I go about getting replacements?
hart2hart
#2 Post by hart2hart » Wed Nov 17, 2021 3:47 am
I’ve never heard of getting free replacements. I had a similar issue when started ripping. I found most of disc used on ebay for good prices but since then eBay prices has gotten much higher.
Make sure you clean and polish discs for deciding they are lost causes. I was able to revive some.
Re: How do I get a replacement for damaged discs?
#3 Post by MartyMcNuts » Wed Nov 17, 2021 6:05 am
grandpixel wrote: Wed Nov 17, 2021 2:07 am So I ripped my collection of about 600 movies, and ended up with about 10 that wouldn't rip because of scratches or otherwise damaged discs. How should I go about getting replacements?
It all depends where and how long ago you bought them. If you are still inside the return window, go for it.
grandpixel
#4 Post by grandpixel » Wed Nov 17, 2021 6:19 am
I contacted all the studios. We'll see who responds and is willing to replace the discs.
#5 Post by Woodstock » Wed Nov 17, 2021 1:45 pm
Some disks that are beyond "just cleaning" can be resurfaced. This works much better with DVDs than BDs, though. And I'd recommend having it done by someone experienced at it, rather than jumping in to buying your own machine and learning how.
Back when I had a Netflix DVD account, I'd just rent the disks that were too bad to rip, and hope. That didn't work out all that often, though, as their disks were in as bad of shape as mine... :roll:
thetoad
#6 Post by thetoad » Sat Nov 27, 2021 1:54 pm
Woodstock wrote: Wed Nov 17, 2021 1:45 pm Some disks that are beyond "just cleaning" can be resurfaced. This works much better with DVDs than BDs, though. And I'd recommend having it done by someone experienced at it, rather than jumping in to buying your own machine and learning how.
this is where you should have used ddrescue (assuming the netflix DVD is the same as yours). as long a damaged in different places, ddrescue would get you a 100% image (then you'd have to stick it through dvd decrypter or another tool to brute force remove the css)
