How do I Uninstall DASPI?
Cavalicious
Post by Cavalicious »
I seem to be having issues since installing DASPI 1.2. In an effort to troubleshoot, I would like to be able to uninstall DASPI. I also noticed that when reading Bluray Discs, that I am capped to 8.8 MB/s or 2.0x. Below is a log when I attempted to rip Star Trek [2009].
Debug log started at Wed Feb 23 04:55:30 2011 , written by MakeMKV v1.6.5 darwin(x86-release)
001005:0000 MakeMKV v1.6.5 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/Cavalicious/MakeMKV_log.txt
002014:0000 Optical drive "DVD+R-DL OPTIARC DVD RW AD-5680H 3AHB" opened in DASPI mode.
002014:0000 Optical drive "BD-RE HL-DT-ST BD-RE  BE08LU20 2.00" opened in DASPI mode.
DISCID=D7F4F568700EE843F32724E9A8295C1285D8450D
003307:0000 File 01000.mpls was added as title #0
003307:0000 File 01001.mpls was added as title #1
003307:0000 File 00000.mpls was added as title #2
003025:0000 Title #00009.mpls has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00012.m2ts was added as title #3
003307:0000 File 00013.m2ts was added as title #4
003025:0000 Title #00014.m2ts has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00015.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01006.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01007.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00011.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory /Volumes/Rips/Star_Trek_Disc_1
001003:0020 DEBUG: Code 1073741829 at 5EoF-:3&s(@1kIfx:29393723
001003:0020 DEBUG: Code 2 at +>@PH894}5 iZK1(:213136562
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '11823740928'
002003:0000 Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '11927353344'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '11937705984'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '11941312512'
002003:0000 Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '11941576704'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '11958939648'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '11960254464'
002003:0000 Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '11963332608'
002003:0000 Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '11963854848'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '11963854848'
001003:0020 DEBUG: Code 0 at #;T"M"((KWQ(BN@0+&DY:29394298
001003:0020 DEBUG: Code 0 at Jv=}O/f18Nlqc%&i6<I=:121261681
001003:0020 DEBUG: Code 0 at #;T"M"((KWQ(BN@0+&DY:29394183
001003:0020 DEBUG: Code 5841726 at #;T"M"((KWQ(BN@0+&DY:29393309
001003:0020 DEBUG: Code 0 at luo#3Eb+D*r/#@J397H>s:29397449
005003:0000 Failed to save title 2 to file /Volumes/Rips/Star_Trek_Disc_1/title02.mkv
005004:0080 0 titles saved, 1 failed
Romansh
Re: How do I Uninstall DASPI?
Post by Romansh »
brian163 offered a suggestion here: http://www.makemkv.com/forum2/viewtopic ... 894#p10894
Disable DASPI:
sudo kextunload /System/Library/Extensions/daspi.kext
Enable DASPI:
sudo kextload /System/Library/Extensions/daspi.kext
I'm not sure whether moving the extension after unloading it is overkill or not.
Cavalicious
Thanks, I'll try unloading. I'll see if Mike sees anything in the log as to why the rip fails.
Post by mike admin »
Did this disc work without DASPI? It looks like a physically damaged disc, please see http://www.makemkv.com/faq/item/7/catid/6
Cavalicious
I did try the BD after unloading DASPI and deleting the file. Failure still happen (which I guess would confirm a damage disc). But I did notice that I was getting better read speeds through OS access.
