MOHAX777
Post
by MOHAX777 » Thu Nov 11, 2021 7:21 pm
bobbymkV wrote: ↑Sun Nov 07, 2021 2:20 pm
MOHAX777 wrote:DennisTheMenace wrote: ↑Mon Nov 01, 2021 4:46 pm
Atmos sound and dolby Vision (Mel and fel) is working now on my ugoos AM6 plus box in kodi.
you are not telling us the whole truth
. Out of about 20 DV-FEL (mkv 7.06), I can watch 2-3 movies without critical problems, the others have frequent problems with picture scattering and freezing. Not to mention problems with rewinding or resuming after stop.
(am6+ 0.42 firmware, lasts kodinerds kodi build)
Which are the few movies you have less issues with?
list of less problem movies:
10 Cloverfield Lane DV-FEL
Donnie Darko DV-MEL
Midsommar DC DV-FEL
mkvcount
Post
by mkvcount » Fri Nov 12, 2021 4:13 am
Anyone know the best and fastest way to count the frame difference on a mac to match/sync the RPU? Haven't found a good way yet...
mkvcount
Post
by mkvcount » Fri Nov 12, 2021 6:11 am
Hope someone can answer this: I have a 23.976fps web-dl with HDR10+ and the same movie in 24fps 4K remux. Is it possible to convert the HDR10+ to DV and inject it to the remux even if the frame rates are different?
DaMacFunkin
Post
by DaMacFunkin » Fri Nov 12, 2021 6:12 am
staknhalo wrote: ↑Thu Nov 11, 2021 3:52 pm
DaMacFunkin wrote: ↑Thu Nov 11, 2021 11:03 am
staknhalo wrote: ↑Sat Sep 11, 2021 11:38 pm
Black Widow UHD + P5 = the same exact source/fames/time stamps = all match exactly
Happy P8 making
Hi, is there a guide for this please?
I can’t get the switches correct with DoVi tool.
I converted HDR+ to DV no problem, now I want to do a UHD (P8) of Black Widow with P5 rpu.
Thanks for any help.
https://www.avsforum.com/threads/author ... 1.3212211/
I logged the steps for p5 to p8 in there
Thanks I had already worked it out from that page
it was the output switches I was by getting right - Black Widow works very well.
If you have a movie where your RPU is offset is there a simple guide to fix this or is is it not worth bothering with?
Ps hoping for a P5 Shang Chi
staknhalo
Post
by staknhalo » Sun Nov 14, 2021 2:38 am
If anyone here in this thread has the French Dolby Vision FEL UHD release of The Incredible Hulk (2008) - if you could give me a mediainfo info 'printout' of the main title (without BL+EL merged but the info for both layers) please and thank you (I know sources would be the same, wondering if its BL is really same as US UHD though not just same source)
daddy
Post
by daddy » Sun Nov 14, 2021 9:40 am
Général
Nom complet : Z:\Marvel et DC Comics\L'Incroyable Hulk [e-ac3][4k][DV]\L'Incroyable Hulk [e-ac3][4k][DV].mp4
Format : MPEG-4
Profil du format : Base Media / Version 2
Identifiant du codec : mp42 (mp42/dby1/isom)
Taille du fichier : 44,7 Gio
Durée : 1 h 52 min
Débit global moyen : 57,0 Mb/s
Date d'encodage : UTC 2021-03-25 13:20:00
Date de marquage : UTC 2021-03-25 13:20:00
Vidéo #1
Format : HEVC
Profil du format : Main 10@L5.1@High
HDR format : SMPTE ST 2086, HDR10 compatible
Identifiant du codec : hev1
Identifiant du codec/Info : High Efficiency Video Coding
Durée : 1 h 52 min
Débit : 50,4 Mb/s
Largeur : 3 840 pixels
Hauteur : 2 160 pixels
Format à l'écran : 16/9
Type d'images/s : Constant
Images par seconde : 23,976 (24000/1001) Im/s
Espace de couleurs : YUV
Sous-échantillonnage de la chrominance : 4:2:0 (Type 2)
Profondeur des couleurs : 10 bits
Bits/(Pixel*Image) : 0.253
Taille du flux : 39,5 Gio (88%)
Default : Non
Gamme de couleurs : Limited
Coordonnées de chromaticité : BT.2020
Caractéristiques du transfert : PQ
Coefficients de la matrice : BT.2020 non-constant
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1000 cd/m2
Maximum Frame-Average Light Level : 657 cd/m2
Codec configuration box : hvcC
Vidéo #2
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Identifiant du codec : dvhe
Identifiant du codec/Info : High Efficiency Video Coding with Dolby Vision
Durée : 1 h 52 min
Débit : 5 678 kb/s
Largeur : 1 920 pixels
Hauteur : 1 080 pixels
Bits/(Pixel*Image) : 0.114
Taille du flux : 4,45 Gio (10%)
Default : Non
Codec configuration box : hvcC+dvcC
Audio
Format : E-AC-3
Format/Info : Enhanced AC-3
Nom commercial : Dolby Digital Plus
Identifiant du codec : ec-3
Durée : 1 h 52 min
Type de débit : Constant
Débit : 960 kb/s
Canaux : 6 canaux
Channel layout : L R C LFE Ls Rs
Echantillonnage : 48,0 kHz
Images par seconde : 31,250 Im/s (1536 SPF)
Mode de compression : Avec perte
Taille du flux : 771 Mio (2%)
Langue : Français
Service kind : Complete Main
Default : Non
quietvoid
Post
by quietvoid » Sun Nov 14, 2021 3:13 pm
So both Firestick 4K 2018 & Max look the same with the Spears & Munsil eagle beak shot.
I tried both original profile 7 and converted to 8.1.
It's not as yellow as with the LG C8 internal player.
L2 metadata isn't being ignored, so this might actually be the player-led issue.
Has anyone reproduced it with another device?
ArArdin
Post
by ArArdin » Sun Nov 14, 2021 3:43 pm
Sorry if this is discussed before. I assume yusesope's tool version (FEL to MEL + UHD-BD to 8.1 + SKIP HDR10+ + Experimental Muxer) is the proper one for adding the "-skip_hdr10plus" switch in the DEMUX.bat, but I can't get this to work.
Commandwindow says "Wait..." and nothing happens for ages. Without the added switch demuxing works fine. Anybody maybe knows why it isn't working?
Much obliged.
staknhalo
Post
by staknhalo » Sun Nov 14, 2021 5:37 pm
daddy wrote: ↑Sun Nov 14, 2021 9:40 am
Général
Format : MPEG-4
Durée : 1 h 52 min
Vidéo #1
Format : HEVC
Durée : 1 h 52 min
Débit : 50,4 Mb/s
Default : Non
Vidéo #2
Format : HEVC
Durée : 1 h 52 min
Débit : 5 678 kb/s
Default : Non
Audio
Format : E-AC-3
Durée : 1 h 52 min
Débit : 960 kb/s
Canaux : 6 canaux
Langue : Français
Default : Non
Thank you very much
mulucy
Post
by mulucy » Mon Nov 15, 2021 4:59 am
quietvoid wrote: ↑Sun Nov 14, 2021 3:13 pm
Not really able to answer your question, but I also own both versions, 2018 and 2021 models of Fire TV 4k Stick. Sorry if I am being redundant with my question. But can we safely say Fire TV 4k Max 2021 model does not play FEL DV, but ignores the El and acts like Nvidia Shield? If this is the case, how accurate the colors are with "MEL" at that point if it's ignoring the EL? Are there any test files to test it out properly @quietvoid? Any way I can help you with the test?
chros
Post
by chros » Mon Nov 15, 2021 9:01 am
I don't think they use player-led (I was the one who suspected it): with our 2018 LG Oleds it's easy to notice, it
produces the same banding/posterization as with HDR10 in PC mode (probably triggering the same low latency mode, where certain basic image processing is disabled).
So Oppo's player-led output is different from Firestick4k's output, there's no such issue with Firestick4k.
So, not sure why it's different, but we saw this with the black level test as well, that's why I stopped using Firestick4k, and use the Plex app on the TV instead.
If you upload samples and tell me exactly when/what to look for I can take a look.
quietvoid
Post
by quietvoid » Mon Nov 15, 2021 3:03 pm
mulucy wrote: ↑Mon Nov 15, 2021 4:59 am
I don't have a profile 7 FEL that looks different to check it out.
I'm pretty sure it ignores the EL, though.
So far regardless of profile 7 or (converted) profile 8, there's a difference in quality for the sample below.
chros wrote: ↑Mon Nov 15, 2021 9:01 am
You can try this sample:
https://mega.nz/file/cY1gEZzQ#eJIRMpZ2X ... PaGtY_35gU
The eagle's beak looks noticeably better in the internal player compared to the Firestick for me.
Next step is probably to try figuring out what's happening and if it can be prevented.
mulucy
Post
by mulucy » Mon Nov 15, 2021 3:30 pm
quietvoid wrote: ↑Mon Nov 15, 2021 3:03 pm
Thanks. I remember someone posted some homebrew videos for FEL to test the P7 on player called Dune? Can't find it anywhere
quietvoid
Post
by quietvoid » Mon Nov 15, 2021 3:47 pm
mulucy wrote: ↑Mon Nov 15, 2021 3:30 pm
They don't work at all on the Firestick.
mulucy
Post
by mulucy » Mon Nov 15, 2021 4:34 pm
quietvoid wrote: ↑Mon Nov 15, 2021 3:47 pm
True. Was able to locate them on avsforums. They don't play at all with Plex. Kodi is not ideal for me, but have you tried it?
