LG WH16NS40 versus WH16NS60 ? Libre versus firmware update ?
MovieLuver
Post by MovieLuver »
Hi people.
Not sure this is the right forum, but here it goes anyway...
I need a new optical drive to rip and play (via MakeMKV streaming) BluRay movies. My media PC is an AMD 3600X running Fedora 35.
I don't understand the difference between the WH16NS60 and the WH16NS40. Why is one "official" and the other is only "supported" ?
Can I stream from MakeMKV if the drive is running in Libre mode ? Or does that require direct access to a drive running the correct firmware ?
Other than the streaming function, what other advantages does running a drive directly have over using Libre ?
Re: LG WH16NS40 versus WH16NS60 ? Libre versus firmware update ?
No difference in makemkv might as well get a WH14NS40 cheaper all the same junk
Streaming can be done but not direct from makemkv
MovieLuver
What is the difference between the '40 and the '60 outside of makemkv ?
Why do these drives have different recommendations in the makemkv forum recommendations ?
makemkv has a streaming function. One can't stream 4K from it ?
MovieLuver
I think this post answers the question -nothing.
https://www.reddit.com/r/makemkv/commen ... en_the_lg/
