ASUS BW-16D1HT Firmware 3.10
Jim79
Post by Jim79 »
Hello all,
The new kid on the block here and I need some help. I have just purchased the ASUS BW-16D1HT with a view to rip my 4k collection to use in Plex. I have the drive installed in an OWC Mercury Pro external enclosure as I'm using it with a Mac Mini (2012) as my Plex server. Plex runs perfectly on it.
This is what I get when It tries to read the UHD
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: KL7K9OI2815
Bus encryption flags: 1F
Harware support: Yes
Firmware support: No
Firmware version: 3.10
So my question is
1. Can I actually update the firmware so that it works, if so where do get it from and how do I install it
2. Is the issue the External enclosure if so which one should I purchase
3. Is the MAC the issue due to its age
Any help is appreciated greatly
Re: ASUS BW-16D1HT Firmware 3.10
See guide below.
No case is fine
No Mac is fine you can flash It just not as easy as windows
If you have a windows pc get an automated flasher if you don't want to do it yourself
Jim79
Post by Jim79 »
Is it something that can be done on a MAC or is it too difficult? I would have to get my hands on a windows device.
Also what is an automated flasher
How easy is all this to do myself or am i best getting someone more technical to do it.
Jim79 wrote: Sun Nov 14, 2021 12:29 am Is it something that can be done on a MAC or is it too difficult? I would have to get my hands on a windows device.
It can be done on Mac just harder I really should update the guide with the Mac commands I'll do that soon and credit who ever posted it have seen it around before
viewtopic.php?f=4&t=23129
That's the post that I remember.
Flashing an optical drive on a Mac requires that you enter a command into Terminal. I wouldn't describe it as hard, but it isn't as simple as point & click. On Windows there are some simple point and click things that'll flash your drive.
