At this point, is this the best way to extract the EL and BL from an MKV? I have been saving a lot of my full disc back-ups, so that I can easily create Blu-Ray folders on my x700 with TS-muxer. I would much rather store my back-ups as MKVs to save on space.Coopervid wrote: Tue Nov 09, 2021 6:26 pmYou can demux the MKV according to this guide and then remux to whatever you like.Katakuri wrote: Wed Nov 03, 2021 9:24 am Hey,
is there an easy way to Remux an MKV with Dolby Vision to an MP4 with Dolby Vision?
My Oppo Clone can't play MKV + DV.
https://forum.redfox.bz/threads/guide-t ... -dv.82545/
jayper
I don't think the ISOs created are larger than the MKVs.
DaMacFunkin
Yes, for starters ISO and M2TS need the ac3 core for TrueHD tracks and with the container overhead it can make them as much as 10% bigger.
johnjon94
Is there any chance you could reupload this? I can't seem to find this version anywhereTrujax wrote: Mon May 11, 2020 9:31 am I have compiled a TsMuxer that forces dvhe.05.06 profile. It works nice where 08.06 played choppy in my Lg. You can find it here http://katfile.com/1uvd80v1b0zd/tsMuxer ... ).zip.html
DaMacFunkin
Hi, is there a guide for this please?staknhalo wrote: Sat Sep 11, 2021 11:38 pm Black Widow UHD + P5 = the same exact source/fames/time stamps = all match exactly
Happy P8 making![]()
I can’t get the switches correct with DoVi tool.
I converted HDR+ to DV no problem, now I want to do a UHD (P8) of Black Widow with P5 rpu.
Thanks for any help.
staknhalo
https://www.avsforum.com/threads/author ... 1.3212211/DaMacFunkin wrote: Thu Nov 11, 2021 11:03 amHi, is there a guide for this please?staknhalo wrote: Sat Sep 11, 2021 11:38 pm Black Widow UHD + P5 = the same exact source/fames/time stamps = all match exactly
I logged the steps for p5 to p8 in there
jayper
Sorry, I should have added more detail. I have both an Nvidia Shield and an x700. I usually do a full disc back-up of my UHDs, from those backups I will create an MKV of the main movie for storage on my server for HDR10 playback on the Shield.DaMacFunkin wrote: Thu Nov 11, 2021 5:45 amYes, for starters ISO and M2TS need the ac3 core for TrueHD tracks and with the container overhead it can make them as much as 10% bigger.
I am one of those people that can really notice the "red push" on the Shield, so I have been hanging onto my full disc back-ups of DoVi discs so that I can create Blu-Ray folders or TS files to playback in Dolby Vision on my x700. Ideally, I could get rid of the full disc back-ups and only save the MKVs. That way I don't have the MKV and full back-up, effectively doubling my stored data. I just wanted to understand the most reliable way to extract all the necessary data from the MKV before tossing my back-ups. I prefer to not re-rip my discs if I can avoid it.
I just had never heard of the tooling in this thread (https://forum.redfox.bz/threads/guide-t ... -dv.82545/) and wanted to know if this was the standard way folks are going about it these days. Thanks!
MOHAX777
list of less problem movies:bobbymkV wrote: Sun Nov 07, 2021 2:20 pmWhich are the few movies you have less issues with?MOHAX777 wrote:you are not telling us the whole truthDennisTheMenace wrote: Mon Nov 01, 2021 4:46 pm Atmos sound and dolby Vision (Mel and fel) is working now on my ugoos AM6 plus box in kodi.. Out of about 20 DV-FEL (mkv 7.06), I can watch 2-3 movies without critical problems, the others have frequent problems with picture scattering and freezing. Not to mention problems with rewinding or resuming after stop.
(am6+ 0.42 firmware, lasts kodinerds kodi build)
10 Cloverfield Lane DV-FEL
Donnie Darko DV-MEL
Midsommar DC DV-FEL
mkvcount
Anyone know the best and fastest way to count the frame difference on a mac to match/sync the RPU? Haven't found a good way yet...
mkvcount
Hope someone can answer this: I have a 23.976fps web-dl with HDR10+ and the same movie in 24fps 4K remux. Is it possible to convert the HDR10+ to DV and inject it to the remux even if the frame rates are different?
DaMacFunkin
Thanks I had already worked it out from that pagestaknhalo wrote: Thu Nov 11, 2021 3:52 pmhttps://www.avsforum.com/threads/author ... 1.3212211/DaMacFunkin wrote: Thu Nov 11, 2021 11:03 amHi, is there a guide for this please?staknhalo wrote: Sat Sep 11, 2021 11:38 pm Black Widow UHD + P5 = the same exact source/fames/time stamps = all match exactly
it was the output switches I was by getting right - Black Widow works very well.
If you have a movie where your RPU is offset is there a simple guide to fix this or is is it not worth bothering with?
Ps hoping for a P5 Shang Chi
staknhalo
If anyone here in this thread has the French Dolby Vision FEL UHD release of The Incredible Hulk (2008) - if you could give me a mediainfo info 'printout' of the main title (without BL+EL merged but the info for both layers) please and thank you (I know sources would be the same, wondering if its BL is really same as US UHD though not just same source)
daddy
Général
Nom complet : Z:\Marvel et DC Comics\L'Incroyable Hulk [e-ac3][4k][DV]\L'Incroyable Hulk [e-ac3][4k][DV].mp4
Format : MPEG-4
Profil du format : Base Media / Version 2
Identifiant du codec : mp42 (mp42/dby1/isom)
Taille du fichier : 44,7 Gio
Durée : 1 h 52 min
Débit global moyen : 57,0 Mb/s
Date d'encodage : UTC 2021-03-25 13:20:00
Date de marquage : UTC 2021-03-25 13:20:00
Vidéo #1
Format : HEVC
Profil du format : Main 10@L5.1@High
HDR format : SMPTE ST 2086, HDR10 compatible
Identifiant du codec : hev1
Identifiant du codec/Info : High Efficiency Video Coding
Durée : 1 h 52 min
Débit : 50,4 Mb/s
Largeur : 3 840 pixels
Hauteur : 2 160 pixels
Format à l'écran : 16/9
Type d'images/s : Constant
Images par seconde : 23,976 (24000/1001) Im/s
Espace de couleurs : YUV
Sous-échantillonnage de la chrominance : 4:2:0 (Type 2)
Profondeur des couleurs : 10 bits
Bits/(Pixel*Image) : 0.253
Taille du flux : 39,5 Gio (88%)
Default : Non
Gamme de couleurs : Limited
Coordonnées de chromaticité : BT.2020
Caractéristiques du transfert : PQ
Coefficients de la matrice : BT.2020 non-constant
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1000 cd/m2
Maximum Frame-Average Light Level : 657 cd/m2
Codec configuration box : hvcC
Vidéo #2
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Identifiant du codec : dvhe
Identifiant du codec/Info : High Efficiency Video Coding with Dolby Vision
Durée : 1 h 52 min
Débit : 5 678 kb/s
Largeur : 1 920 pixels
Hauteur : 1 080 pixels
Bits/(Pixel*Image) : 0.114
Taille du flux : 4,45 Gio (10%)
Default : Non
Codec configuration box : hvcC+dvcC
Audio
Format : E-AC-3
Format/Info : Enhanced AC-3
Nom commercial : Dolby Digital Plus
Identifiant du codec : ec-3
Durée : 1 h 52 min
Type de débit : Constant
Débit : 960 kb/s
Canaux : 6 canaux
Channel layout : L R C LFE Ls Rs
Echantillonnage : 48,0 kHz
Images par seconde : 31,250 Im/s (1536 SPF)
Mode de compression : Avec perte
Taille du flux : 771 Mio (2%)
Langue : Français
Service kind : Complete Main
Default : Non
quietvoid
So both Firestick 4K 2018 & Max look the same with the Spears & Munsil eagle beak shot.
I tried both original profile 7 and converted to 8.1.
It's not as yellow as with the LG C8 internal player.
L2 metadata isn't being ignored, so this might actually be the player-led issue.
Has anyone reproduced it with another device?
ArArdin
yusesope's tool - Removing HDR10+ metadata
Sorry if this is discussed before. I assume yusesope's tool version (FEL to MEL + UHD-BD to 8.1 + SKIP HDR10+ + Experimental Muxer) is the proper one for adding the "-skip_hdr10plus" switch in the DEMUX.bat, but I can't get this to work.
Commandwindow says "Wait..." and nothing happens for ages. Without the added switch demuxing works fine. Anybody maybe knows why it isn't working?
Much obliged.
Much obliged.
