As with most movies, you can ignore the checkboxes for "forced only", since the flag it depends on is rarely used. Even if you select them, you'll get a message at the end of the rip saying they were empty and deleted.
Then you just have to check the correct track. Most use 3, but some use 7.
Or let MakeMKV rip them all, look at the resulting MKV file with VLC to identify the correct track(s), and use mkvtoolnix to remove the ones you don't want.
Star Wars The Complete Saga Blue Ray Alien Subtitles Missing
Re: Star Wars The Complete Saga Blue Ray Alien Subtitles Missing
oatmeal769
Image link broken.engrdan wrote: Tue Nov 09, 2021 7:20 pm Did you end up just checking the box for the 4th PGS English subtitles and skipped the PGS English forced only?
I checked boxes for everything. Then I went through and figured out which one had the subtitles.
engrdan
Thanks for the reply's. Sorry the link was busted. That's the first pic I've tried to link on this forum. Hoping this Dropbox link will work
https://www.dropbox.com/s/t5twd2g8xa0q9 ... v.JPG?dl=0
I've tried multiple tracks (I think 1st, 2nd, and third, and fourth individually) of forced English and full English subtitles but never all at once. I've never used VLC or mkvtoolnix. I only have experience with MakeMKV so far.
