MOHAX777
Post by MOHAX777 » Sat Nov 06, 2021 8:01 pm
DennisTheMenace wrote:
Mon Nov 01, 2021 4:46 pm
Atmos sound and dolby Vision (Mel and fel) is working now on my ugoos AM6 plus box in kodi.
you are not telling us the whole truth :D . Out of about 20 DV-FEL (mkv 7.06), I can watch 2-3 movies without critical problems, the others have frequent problems with picture scattering and freezing. Not to mention problems with rewinding or resuming after stop.
(am6+ 0.42 firmware, lasts kodinerds kodi build)
bobbymkV
Post by bobbymkV » Sun Nov 07, 2021 2:20 pm
Which are the few movies you have less issues with?
Post by Coopervid » Tue Nov 09, 2021 6:26 pm
Katakuri wrote:
Wed Nov 03, 2021 9:24 am
Hey,
is there an easy way to Remux an MKV with Dolby Vision to an MP4 with Dolby Vision?
My Oppo Clone can't play MKV + DV.
You can demux the MKV according to this guide and then remux to whatever you like.
https://forum.redfox.bz/threads/guide-t ... -dv.82545/
jayper
Post by jayper » Wed Nov 10, 2021 6:33 am
Hey,
At this point, is this the best way to extract the EL and BL from an MKV? I have been saving a lot of my full disc back-ups, so that I can easily create Blu-Ray folders on my x700 with TS-muxer. I would much rather store my back-ups as MKVs to save on space.
Post by Coopervid » Wed Nov 10, 2021 7:45 pm
I don't think the ISOs created are larger than the MKVs.
DaMacFunkin
Post by DaMacFunkin » Thu Nov 11, 2021 5:45 am
Yes, for starters ISO and M2TS need the ac3 core for TrueHD tracks and with the container overhead it can make them as much as 10% bigger.
johnjon94
Post by johnjon94 » Thu Nov 11, 2021 7:46 am
Trujax wrote:
Mon May 11, 2020 9:31 am
I have compiled a TsMuxer that forces dvhe.05.06 profile. It works nice where 08.06 played choppy in my Lg. You can find it here http://katfile.com/1uvd80v1b0zd/tsMuxer ... ).zip.html
Is there any chance you could reupload this? I can't seem to find this version anywhere
DaMacFunkin
Post by DaMacFunkin » Thu Nov 11, 2021 11:03 am
staknhalo wrote:
Sat Sep 11, 2021 11:38 pm
Black Widow UHD + P5 = the same exact source/fames/time stamps = all match exactly
Happy P8 making :)
Hi, is there a guide for this please?
I can’t get the switches correct with DoVi tool.
I converted HDR+ to DV no problem, now I want to do a UHD (P8) of Black Widow with P5 rpu.
Thanks for any help.
staknhalo
Post by staknhalo » Thu Nov 11, 2021 3:52 pm
Happy P8 making :)
https://www.avsforum.com/threads/author ... 1.3212211/
I logged the steps for p5 to p8 in there
jayper
Post by jayper » Thu Nov 11, 2021 5:36 pm
Sorry, I should have added more detail. I have both an Nvidia Shield and an x700. I usually do a full disc back-up of my UHDs, from those backups I will create an MKV of the main movie for storage on my server for HDR10 playback on the Shield.
I am one of those people that can really notice the "red push" on the Shield, so I have been hanging onto my full disc back-ups of DoVi discs so that I can create Blu-Ray folders or TS files to playback in Dolby Vision on my x700. Ideally, I could get rid of the full disc back-ups and only save the MKVs. That way I don't have the MKV and full back-up, effectively doubling my stored data. I just wanted to understand the most reliable way to extract all the necessary data from the MKV before tossing my back-ups. I prefer to not re-rip my discs if I can avoid it.
I just had never heard of the tooling in this thread (https://forum.redfox.bz/threads/guide-t ... -dv.82545/) and wanted to know if this was the standard way folks are going about it these days. Thanks!
MOHAX777
Post by MOHAX777 » Thu Nov 11, 2021 7:21 pm
list of less problem movies:
10 Cloverfield Lane DV-FEL
Donnie Darko DV-MEL
Midsommar DC DV-FEL
mkvcount
Post by mkvcount » Fri Nov 12, 2021 4:13 am
Anyone know the best and fastest way to count the frame difference on a mac to match/sync the RPU? Haven't found a good way yet...
mkvcount
Post by mkvcount » Fri Nov 12, 2021 6:11 am
Hope someone can answer this: I have a 23.976fps web-dl with HDR10+ and the same movie in 24fps 4K remux. Is it possible to convert the HDR10+ to DV and inject it to the remux even if the frame rates are different?
DaMacFunkin
Post by DaMacFunkin » Fri Nov 12, 2021 6:12 am
Happy P8 making :)
Thanks I had already worked it out from that page
it was the output switches I was by getting right - Black Widow works very well.
If you have a movie where your RPU is offset is there a simple guide to fix this or is is it not worth bothering with?
Ps hoping for a P5 Shang Chi 😉
staknhalo
Post by staknhalo » Sun Nov 14, 2021 2:38 am
If anyone here in this thread has the French Dolby Vision FEL UHD release of The Incredible Hulk (2008) - if you could give me a mediainfo info 'printout' of the main title (without BL+EL merged but the info for both layers) please and thank you (I know sources would be the same, wondering if its BL is really same as US UHD though not just same source)
