Black Widow
Daveo
Re: Black Widow
Post by Daveo »
For me this keeps stopping about 60% through i get this
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00055.m2ts' at offset '27308716032'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '27308716032'
Failed to save title 0 to file E:/MARVEL/MARVEL STUDIOS' BLACK WIDOW - ULTRA HD_t00.mkv
Encountered 23 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
Im on my aecond disk now and have cleaned it thoroughly .. I seem to be getting more and more problems this last month or so.
Ive tried on different versions of makemkv.
Bluntman
Re: Black Widow
Post by Bluntman »
Might want to try disabling speed control for dual and triple layer. U2=-;U3=-
Sent from my iPad using Tapatalk Pro
monkfish
Re: Black Widow
Post by monkfish »
dante01 wrote: Tue Sep 14, 2021 8:39 am I'm also have issues with this disc and repeatedly get the following message:
DEBUG: Code 0 at HE<hEO<!JUR7.k';:29396092
DEBUG: Code 0 at HE<hEO<!JUR7.k';:29395172
I've posted ed the associated TGZ file to Mike.
2 months later and its still an issue, sent another key just in case there is a variant disc doing the rounds. (UK version - Amazon)
Re: Black Widow
Post by SamuriHL »
And you're absolutely sure MakeMKV is downloading new keys?
monkfish
Re: Black Widow
Post by monkfish »
SamuriHL wrote: Sat Nov 06, 2021 8:17 pm And you're absolutely sure MakeMKV is downloading new keys?
Yep , completely removed the file and let it download again, same issue. Either Mike has missed a file somewhere, hasn't time to do it, or there is another revision in the open.
Re: Black Widow
Post by SamuriHL »
Any and all of that is possible. As long as you sent the dump to the proper email address, it's simply a waiting game and to keep checking periodically to see when the key is released. There is no set amount of time when that may happen. Could be hours, could be days, could be weeks. All depends on when Mike gets around to it.
cslcm
Re: Black Widow
Post by cslcm »
I wonder if there is a particular technical challenge with this disc. The two main "competitors" can't handle the disc either.
Re: Black Widow
Post by SamuriHL »
There IS a possibility of a bad disc that's producing results that can't be decrypted. That doesn't happen often and you'd usually see a lot of read errors trying to read the disc in that case.
DeadPixel
Re: Black Widow
Post by DeadPixel »
my UK disc from amazon decrypted fine if it helps
monkfish
Re: Black Widow
Post by monkfish »
DeadPixel wrote: Tue Nov 09, 2021 9:12 am my UK disc from amazon decrypted fine if it helps
Weird , I'm away working currently, but I get back I will check the disc in the Xbox just in case.
cslcm
Re: Black Widow
Post by cslcm »
DeUHD is now able to decrypt my disc. My best guess is that they have experimented with Black Widow to see if they could slow piracy by making more editions with more keys. *Shrugs*
monkfish
Re: Black Widow
Post by monkfish »
Ripping as we speak.
Thanks Mike!
QuiJohnGinn
Re: Black Widow
Post by QuiJohnGinn »
monkfish wrote: Fri Nov 12, 2021 9:04 pm Ripping as we speak.
Thanks Mike!
Was it a new key update? Just got a copy from Best Buy and I'm getting the unknown key. AFAIK I'm all updated.
kelvor
Re: Black Widow
Post by kelvor »
Just received my copy of Black Widow UHD from Amazon (US version) and it is failing to decrypt. I sent in my tgz file. Seems likely they are using multiple different keys to throw off decryption.
Re: Black Widow
QuiJohnGinn wrote: Sat Nov 13, 2021 7:55 pm Was it a new key update? Just got a copy from Best Buy and I'm getting the unknown key. AFAIK I'm all updated.
Email the file MakeMKV made in that situation to svq@makemkv.com
Fixing Volume Key is Unknown
