bobbymkV
Post by bobbymkV » Thu Nov 04, 2021 2:23 am
Yeah, I tried the nexus build and it's actually worse for me as the audio never gets in sync. And getting the FEL videos to kick off is worse as well as I have to open up the task menu every time just to get them to start, which they will in the bottom right corner. Then I have to re-open Kodi to bring it to full screen. Strange behavior, nothing new.
DennisTheMenace
Post by DennisTheMenace » Thu Nov 04, 2021 5:12 am
Hmm OK strange, I only have some audio dropouts from time to time, that's all.
But like I said they are also on the shield right now. You have installed the nightly version ?
Maybe the TV matters ? I'm using Sony a90j but directly connected to my receiver of my Ht-a9 Soundsystem.
But OK, I will check it again, when a mod of a official kodi 19.4 version is out
DaMacFunkin
Post by DaMacFunkin » Thu Nov 04, 2021 5:50 am
When I had my minix /Ugoos I killed all processes and cleared cache before every attempt to play a movie, it seemed to work better like that, if I’m being honest I think the device doesn’t have enough tam or how the cache is fed through the Ram is suitable for such high bitrate files.
I’ve given up on it all I just stick with the Z9X now.
bobbymkV
Post by bobbymkV » Thu Nov 04, 2021 8:19 am
I installed the same apk you linked me to directly above. I tried playing a rip of 1917 and made sure to play it directly after a reboot. The only thing I can think of is you have some magic combination of device settings. I think there might have been another release candidate firmware for this device, but I didn't get around to installing it yet and that's primarily because I doubt it changes anything related to FEL playback (I'm on 0.4.1). Are you sure the files you are testing have Full Enhancement Layer?
DennisTheMenace
Post by DennisTheMenace » Fri Nov 05, 2021 7:54 am
Yes I'm sure
Apocalypse n.. (remux) are played without any stutter and with atmos.
But like I said with sound dropouts here and there.
I'm going back to use my zidoo z9x.
But if they can fix the dropouts I think I use the ugoos.
Are you playing it in kodi (nexus, master) with the newest kodinerds version ?
I also have the 0.42 firmware installed, if that matters.
When you still have problems, I'm sorry, I can't help
Buzzie
Post by Buzzie » Fri Nov 05, 2021 9:41 am
Hey Guys,
I have been browsing a lot of pages this morning but i cant seem to find it.
I know there is a way to extract the DV layer from a WEB-DL file and add it to the UHD file to have a hybrid release that contains DV and all the original info that was in the UHD MKV.
Is there a guide for noobs how to get this done??
Thanks in advance.
MOHAX777
Post by MOHAX777 » Sat Nov 06, 2021 8:01 pm
Mon Nov 01, 2021 4:46 pm
Atmos sound and dolby Vision (Mel and fel) is working now on my ugoos AM6 plus box in kodi.
you are not telling us the whole truth :D . Out of about 20 DV-FEL (mkv 7.06), I can watch 2-3 movies without critical problems, the others have frequent problems with picture scattering and freezing. Not to mention problems with rewinding or resuming after stop.
(am6+ 0.42 firmware, lasts kodinerds kodi build)
bobbymkV
Post by bobbymkV » Sun Nov 07, 2021 2:20 pm
Which are the few movies you have less issues with?
Post by Coopervid » Tue Nov 09, 2021 6:26 pm
Katakuri wrote:
Wed Nov 03, 2021 9:24 am
Hey,
is there an easy way to Remux an MKV with Dolby Vision to an MP4 with Dolby Vision?
My Oppo Clone can't play MKV + DV.
You can demux the MKV according to this guide and then remux to whatever you like.
https://forum.redfox.bz/threads/guide-t ... -dv.82545/
jayper
Post by jayper » Wed Nov 10, 2021 6:33 am
Hey,
At this point, is this the best way to extract the EL and BL from an MKV? I have been saving a lot of my full disc back-ups, so that I can easily create Blu-Ray folders on my x700 with TS-muxer. I would much rather store my back-ups as MKVs to save on space.
Post by Coopervid » Wed Nov 10, 2021 7:45 pm
I don't think the ISOs created are larger than the MKVs.
DaMacFunkin
Post by DaMacFunkin » Thu Nov 11, 2021 5:45 am
Yes, for starters ISO and M2TS need the ac3 core for TrueHD tracks and with the container overhead it can make them as much as 10% bigger.
johnjon94
Post by johnjon94 » Thu Nov 11, 2021 7:46 am
Trujax wrote:
Mon May 11, 2020 9:31 am
I have compiled a TsMuxer that forces dvhe.05.06 profile. It works nice where 08.06 played choppy in my Lg. You can find it here http://katfile.com/1uvd80v1b0zd/tsMuxer ... ).zip.html
Is there any chance you could reupload this? I can't seem to find this version anywhere
DaMacFunkin
Post by DaMacFunkin » Thu Nov 11, 2021 11:03 am
staknhalo wrote:
Sat Sep 11, 2021 11:38 pm
Black Widow UHD + P5 = the same exact source/fames/time stamps = all match exactly
Happy P8 making :)
Hi, is there a guide for this please?
I can’t get the switches correct with DoVi tool.
I converted HDR+ to DV no problem, now I want to do a UHD (P8) of Black Widow with P5 rpu.
Thanks for any help.
staknhalo
Post by staknhalo » Thu Nov 11, 2021 3:52 pm
Happy P8 making :)
https://www.avsforum.com/threads/author ... 1.3212211/
I logged the steps for p5 to p8 in there
