DennisTheMenace
#5701 Post by DennisTheMenace » Wed Nov 03, 2021 6:30 am
bobbymkV wrote:
Wed Nov 03, 2021 12:02 am
DennisTheMenace wrote:
Mon Nov 01, 2021 4:46 pm
Atmos sound and dolby Vision (Mel and fel) is working now on my ugoos AM6 plus box in kodi.
But that error that you've to start a movie sometimes still exist.
But that horrible stutter from a long time ago is gone
I have to do some more testing
Edit im getting some short sound dropouts with dolby true-hd atmos every 10 minutes, I hope they can fix this, time will tell
I'm one of the crazy bastards that purchased an AM6+ lol. Is this the apk you are using then -- https://www.dropbox.com/sh/0n37s3j3iybw ... a.apk?dl=0 ??
I'd like to test.
Hi I have installed the nexus master version, because that's the one it gets updated first
https://www.dropbox.com/sh/5fjkqnuvwa7z ... bi-v7a.apk
There are often updates at the moment because they are in the process of fixing bugs, As I said, sometimes I still have very brief sound dropouts. But the stutter of the video is gone now.
But that dropouts are also on the shield right now, it has nothing to do with the ugoos only.
there is an updater add-on that you can update the dv build from within kodi. but you have to be registered in the forum to be able to download it. and as I said I use the nexus nightly build here is the link to the updater addon, if you want to use it
The forum is in German
https://www.kodinerds.net/filebase/inde ... dard-Fire/
i really hope they can fix all of the bugs. then the ugoos player would be the perfect player due to the possibility of processing fel dv.
half a year ago, Kodi was not usable on the ugoos because dolby vision videos and hd sound stuttered. They are now one step further
Katakuri
#5702 Post by Katakuri » Wed Nov 03, 2021 9:24 am
Hey,
is there an easy way to Remux an MKV with Dolby Vision to an MP4 with Dolby Vision?
My Oppo Clone can't play MKV + DV.
#5703 Post by RESET_9999 » Wed Nov 03, 2021 3:10 pm
Hey,
TS/m2ts or bluray folder is what you want.
https://github.com/justdan96/tsMuxer/releases
#5704 Post by RESET_9999 » Wed Nov 03, 2021 5:10 pm
I know there is the bluray player oppo clone M9205 but what is this 65$ version? if it's only missing a bluray disc drive , I don't mind at this price as long as it can play rip via network or usb.
http://www.hdlsl.com/
PlatypusW
#5705 Post by PlatypusW » Wed Nov 03, 2021 5:29 pm
I’m pretty sure that’s just the upfront amount / deposit before having to pay the full amount. At least that’s how the group bulk purchases worked - fairly certain this site is just mimicking that?
bobbymkV
#5706 Post by bobbymkV » Wed Nov 03, 2021 7:48 pm
I'd like to test.
Thanks for keeping the dream alive in regards to the AM6+. I wasn't sure if the FEL playback would ever improve and it seemed like the stuttering was something that Ugoos was never going to be able to address themselves. Hopefully I will find some free time soon to test this new Kodi build!
#5707 Post by shawnc22 » Wed Nov 03, 2021 8:09 pm
Yeah, pretty sure that's what it is. And if customs gives you trouble about the shipment, you can then show them the deposit payment instead of a full $300-$500 payment to avoid paying a hefty import cost.
#5708 Post by RESET_9999 » Wed Nov 03, 2021 10:00 pm
thank's guys, make sense.
Mattl0
#5709 Post by Mattl0 » Wed Nov 03, 2021 11:53 pm
I'd like to test.
Still have sluttering here with the last kodinerd build. Will try the nexusbuild.
edit: Same result.
Pretty sure the only way to watch anything on this box is with with the default videoplayer. But I think they do something wrong is the rgb tunnelling process.. I do not trust the box anymore.
bobbymkV
#5710 Post by bobbymkV » Thu Nov 04, 2021 2:23 am
Yeah, I tried the nexus build and it's actually worse for me as the audio never gets in sync. And getting the FEL videos to kick off is worse as well as I have to open up the task menu every time just to get them to start, which they will in the bottom right corner. Then I have to re-open Kodi to bring it to full screen. Strange behavior, nothing new.
DennisTheMenace
#5711 Post by DennisTheMenace » Thu Nov 04, 2021 5:12 am
Hmm OK strange, I only have some audio dropouts from time to time, that's all.
But like I said they are also on the shield right now. You have installed the nightly version ?
Maybe the TV matters ? I'm using Sony a90j but directly connected to my receiver of my Ht-a9 Soundsystem.
But OK, I will check it again, when a mod of a official kodi 19.4 version is out
DaMacFunkin
#5712 Post by DaMacFunkin » Thu Nov 04, 2021 5:50 am
When I had my minix /Ugoos I killed all processes and cleared cache before every attempt to play a movie, it seemed to work better like that, if I’m being honest I think the device doesn’t have enough tam or how the cache is fed through the Ram is suitable for such high bitrate files.
I’ve given up on it all I just stick with the Z9X now.
bobbymkV
#5713 Post by bobbymkV » Thu Nov 04, 2021 8:19 am
I installed the same apk you linked me to directly above. I tried playing a rip of 1917 and made sure to play it directly after a reboot. The only thing I can think of is you have some magic combination of device settings. I think there might have been another release candidate firmware for this device, but I didn't get around to installing it yet and that's primarily because I doubt it changes anything related to FEL playback (I'm on 0.4.1). Are you sure the files you are testing have Full Enhancement Layer?
DennisTheMenace
#5714 Post by DennisTheMenace » Fri Nov 05, 2021 7:54 am
Yes I'm sure
Apocalypse n.. (remux) are played without any stutter and with atmos.
But like I said with sound dropouts here and there.
I'm going back to use my zidoo z9x.
But if they can fix the dropouts I think I use the ugoos.
Are you playing it in kodi (nexus, master) with the newest kodinerds version ?
I also have the 0.42 firmware installed, if that matters.
When you still have problems, I'm sorry, I can't help
Buzzie
#5715 Post by Buzzie » Fri Nov 05, 2021 9:41 am
Hey Guys,
I have been browsing a lot of pages this morning but i cant seem to find it.
I know there is a way to extract the DV layer from a WEB-DL file and add it to the UHD file to have a hybrid release that contains DV and all the original info that was in the UHD MKV.
Is there a guide for noobs how to get this done??
Thanks in advance.
