UHD RIP Segments
DiagonalAce
UHD RIP Segments
Post by DiagonalAce »
I've been using Make MKV for a long time now, and have always been able to find a solutions when up against a problem. However, this time no luck.
I have a LibreDrive that I've been using for awhile, and have ripped multiple 4K videos in the past. However, now I've run into an issue. In an attempt to rip Spider-Man Homecoming, among others, I have observed multiple files (same number of Chapters, Duration, etc etc). Now usually I would just play the disk while running Process Monitor to figure out the correct file by figuring out the correct segment, however, now I've been running into an issue where I can't play some 4K UHD disks on my computer because of Intel SGX, therfore preventing me from being able to find out the correct sequence.
Does anyone have a solution to figure out the correct sequence without having to have to buy a brand new computer with hardware that supports Intel SGX?
Re: UHD RIP Segments
use vlc + makemkv integration
DiagonalAce
Billycar11 wrote: Wed Nov 03, 2021 4:31 am use vlc + makemkv integration
Sadly that did not work (unless I'm doing it wrong). I clicked on the check mark box to integrate, however although VLC would attempt to play the disk (supper choppy) and with no menus as which seems to be another issue in and of itself, nothing would show up on the ProcessMonitor to allow me to confirm the correct source file.
Starting to think I'm just not going to be able to have some of my Video's in 4K on my PLEX Server (and just use the included 1080 disk). Also ran into the issue of Civil War in 4K not being able to open on MKV now. :|
DiagonalAce wrote: Thu Nov 04, 2021 5:57 am
The super chopy problem is your pc not having h.265 decoding the no menus is no java
In the vlc playlist drop down is where you see the tracks
