Re: Ultimate UHD Drives Flashing Guide Updated 2021
#886 Post by Billycar11 » Tue Nov 02, 2021 11:34 pm
kuro2K20 wrote:
Tue Nov 02, 2021 11:06 pm
If I buy an LG BH16NS55, I am sure it will be UHD compatible ? (after flashing with WH16NS60 1.02MK firmware...)
Will I then be able to burn BD-R/RE or it will be blocked and in fact, I will only be able to read my BRD and BRD UHD ?
should still be able to burn if not flash to BH16NS55 1.05mk and try again
kuro2K20
#887 Post by kuro2K20 » Wed Nov 03, 2021 12:06 am
You advise me to flash first with which firmware ?
BH16NS55 1.05MK ?
What's the diffence with the WH16NS60 1.02MK ?
Thanks ;)
#888 Post by Billycar11 » Wed Nov 03, 2021 3:04 am
BH16NS55 1.05MK ?
Thanks ;)
Flash WH16NS60 first it's faster and has no sleep bug
If burning fails then go to 1.05
kuro2K20
#889 Post by kuro2K20 » Wed Nov 03, 2021 6:12 pm
Ok ! ^^
Anyway, I am thinking of using the LG just for making UHD backups and using my Pioneer only for burning...
If I crossflash with the firmware from Asus, I will no longer be able to burn ... :(
romadelic
#890 Post by romadelic » Tue Nov 09, 2021 12:52 pm
Hi.
Please help me figure out this issue:
LG WH16NS60 has 1.02MK firmware. Is it possible to flash 1.02MK to 1.00? And what is the best way to do it?
#891 Post by Coopervid » Tue Nov 09, 2021 4:17 pm
This:
viewtopic.php?f=16&t=22896
and 1.00 is in the DE firmware pack you can also load from this site.
Tober27
#892 Post by Tober27 » Wed Nov 10, 2021 11:28 am
I just got this one:
https://www.amazon.com.au/gp/product/B0 ... UTF8&psc=1
Can it be flashed? (I'm new)
#893 Post by Coopervid » Wed Nov 10, 2021 2:27 pm
Run Makemkv and it will tell you.
Tober27
#894 Post by Tober27 » Wed Nov 10, 2021 9:41 pm
It doesn't seem to tell me anything. It shows "No disc inserted".
That is with a 4K disc inserted. Blu-ray seems to be read fine.
#895 Post by Woodstock » Wed Nov 10, 2021 11:24 pm
Start MakeMKV. Look at the part of the display marked "Info". You should see information like:
Product: BDDVDRW UH08LS10
Revision: 2.00
Serial number: H9M9B395441
Firmware date: 2009-10-26 12:34:56
Highest AACS version: 76
Status: Possible, might be supported in future, but not likely soon
Drive platform: RS1013
Firmware version: 2.00-00
The information under "LibreDrive Information" will tell you if the drive is possible to use under LibreDrive, and if any flashing is necessary. The one I got the information from above isn't flashable right now.
#896 Post by Woodstock » Wed Nov 10, 2021 11:28 pm
Your link describes the drive as "Ultra Slim External 4K UHD", which means it is going to not be UHD-friendly without firmware changes. "UHD Official" drives lock out attempts to rip the video from UHD disks.
The LD information will be necessary.
Tober27
#897 Post by Tober27 » Wed Nov 10, 2021 11:31 pm
No "LibreDrive Information". Just:
Product: BD-RE BU40N
Revision: DN13
Serial number: MO9K6D81503
Firmware date: 2119-07-04 14:26
Bus encryption flags: 1F
Highest AACS version: 63
Am I missing something?
#898 Post by Woodstock » Thu Nov 11, 2021 1:32 am
What version of MakeMKV are you running? A BU40N drive should show good LD information...
Tober27
#899 Post by Tober27 » Thu Nov 11, 2021 1:38 am
MakeMKV v1.16.5 [win(x64-release)]
GUI version: v1.16.5 [win(x86-release)]
License type: Time-limited
Am I not using the right one?
#900 Post by MartyMcNuts » Thu Nov 11, 2021 1:43 am
Try taking the disc out.
