should still be able to burn if not flash to BH16NS55 1.05mk and try again
Re: Ultimate UHD Drives Flashing Guide Updated 2021
You advise me to flash first with which firmware ?
BH16NS55 1.05MK ?
What's the diffence with the WH16NS60 1.02MK ?
BH16NS55 1.05MK ?
Flash WH16NS60 first it's faster and has no sleep bug
If burning fails then go to 1.05
Ok ! ^^
Anyway, I am thinking of using the LG just for making UHD backups and using my Pioneer only for burning...
If I crossflash with the firmware from Asus, I will no longer be able to burn ...
Hi.
Please help me figure out this issue:
LG WH16NS60 has 1.02MK firmware. Is it possible to flash 1.02MK to 1.00? And what is the best way to do it?
This:
viewtopic.php?f=16&t=22896
and 1.00 is in the DE firmware pack you can also load from this site.
I just got this one:
https://www.amazon.com.au/gp/product/B0 ... UTF8&psc=1
Can it be flashed? (I'm new)
Run Makemkv and it will tell you.Tober27 wrote: ↑Wed Nov 10, 2021 11:28 amI just got this one:
It doesn't seem to tell me anything. It shows "No disc inserted".Run Makemkv and it will tell you.
That is with a 4K disc inserted. Blu-ray seems to be read fine.
Start MakeMKV. Look at the part of the display marked "Info". You should see information like:
The information under "LibreDrive Information" will tell you if the drive is possible to use under LibreDrive, and if any flashing is necessary. The one I got the information from above isn't flashable right now.Drive Information
Product: BDDVDRW UH08LS10
Revision: 2.00
Serial number: H9M9B395441
Firmware date: 2009-10-26 12:34:56
Highest AACS version: 76
Status: Possible, might be supported in future, but not likely soon
Drive platform: RS1013
Firmware version: 2.00-00
Your link describes the drive as "Ultra Slim External 4K UHD", which means it is going to not be UHD-friendly without firmware changes. "UHD Official" drives lock out attempts to rip the video from UHD disks.
The LD information will be necessary.
No "LibreDrive Information". Just:
Product: BD-RE BU40N
Revision: DN13
Serial number: MO9K6D81503
Firmware date: 2119-07-04 14:26
Bus encryption flags: 1F
Highest AACS version: 63
Am I missing something?
What version of MakeMKV are you running? A BU40N drive should show good LD information...
Try taking the disc out.
