Source file corrupt error
AndersUA
#1 Post by AndersUA » Mon Feb 14, 2011 11:16 pm
I have copied bunch of my home video DVD to the HDD and then tried to convert them into mkvs
Majority worked fine (1 title identified), however few of them, where MakeMKV identified 2 or more titles, I got error -
"The source file ХХХХ is corrupt or invalid at offset NNNNNNN attempting to work around"
Then a lot of lines with changed numbers and message that file was not saved
Last file for the lowest title was copied fine
Presume its a kind of problem with ending of the episode with another episode, somehow they can not be merged
I tried to select only first title and run makemkv but in vain
Please help
AndersUA
Re: Source file corrupt error
#2 Post by AndersUA » Wed Feb 16, 2011 11:42 am
Anyone?
crowfax
#3 Post by crowfax » Wed Feb 16, 2011 3:18 pm
Damaged / poorly manufactured disc. Swap it for a new one.
AndersUA
#4 Post by AndersUA » Wed Feb 16, 2011 3:34 pm
I burned the disks by myself, so I dont have spare one to swap. All DVDs are readable and copiable OK - actually makemkv works with disks contents, already copied to HDD
ALL of the disks where only 1 title was identified by program, were converted fine
ALL those where 2 or more titles we found were tagged as "corrupt"
At those, last title was converted OK
It hardly relates to disk manufacturing problem, clearly a software issue, conflicting with titles merging
Appreciate advise
#5 Post by mike admin » Thu Feb 17, 2011 10:12 am
AndersUA wrote:actually makemkv works with disks contents, already copied to HDD
That means that IFO files are incorrect.
How did you author these discs?
Does it work if you open IFO file from disc via File-Open menu and ignore warning?
AndersUA
#6 Post by AndersUA » Thu Feb 17, 2011 11:55 am
mike admin wrote:That means that IFO files are incorrect.
Well, disks were burned and finalised by standalone recorder
Now I copied disks to HDD and intended to convert them to mkvs (my media player doesnt like VIDEO_RM directory, seemingly)
You mean file-open menu of Media Player? It works absolutely fine
Makemkv also gives no warning until actually hitting the end of first title during actual conversion
What bothers me is that program is unable to convert individual title separately
#7 Post by mike admin » Sat Feb 19, 2011 10:20 am
AndersUA wrote:
mike admin wrote:You mean file-open menu of Media Player? It works absolutely fine
No, I mean in MakeMKV. Do not press big open button but select "Open" from file menu, navigate to disc root, select VIDEO_TS.ifo and ignore the next warning message.
AndersUA
#8 Post by AndersUA » Sat Feb 19, 2011 1:38 pm
Opened fine, no warnings, here is the log:
MakeMKV v1.6.4 win(x86-release) started
The new version 1.6.5 is available for download at http://www.makemkv.com/download
Opening files on harddrive at D:/Home movies/Family/1 Архив ДВД 2000-2010/Дети/Дети 1 февраль 2000 - декабрь 2003/Диск 6 15 сентября 2001 - 19 января 2002 mkv не полностью/VIDEO_TS/
Calculated BUP offset for VTS #0 does not match one in IFO header.
Calculated BUP offset for VTS #1 does not match one in IFO header.
Titleset start sector mismatch for titleset 1 : 2336 != 5120
Title #0 was added (6 cell(s), 0:13:04)
Title #1 was added (46 cell(s), 1:54:36)
Title #2 was added (6 cell(s), 0:13:04)
Title #3 was added (46 cell(s), 1:54:36)
Title 3 in VTS 1 is equal to title 1 and was skipped
Title 4 in VTS 1 is equal to title 2 and was skipped
But when I pressed for saving as mkv, again all these errors appeared
Saving 2 titles into directory D:/Home movies/Family/1 Архив ДВД 2000-2010/Дети/Дети 1 февраль 2000 - декабрь 2003/Диск 6 15 сентября 2001 - 19 января 2002 mkv не полностью
The source file 'D:/Home movies/Family/1 Архив ДВД 2000-2010/Дети/Дети 1 февраль 2000 - декабрь 2003/Диск 6 15 сентября 2001 - 19 января 2002 mkv не полностью/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 466196480, attempting to work around
The source file 'D:/Home movies/Family/1 Архив ДВД 2000-2010/Дети/Дети 1 февраль 2000 - декабрь 2003/Диск 6 15 сентября 2001 - 19 января 2002 mkv не полностью/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 466198528, attempting to work around
The source file 'D:/Home movies/Family/1 Архив ДВД 2000-2010/Дети/Дети 1 февраль 2000 - декабрь 2003/Диск 6 15 сентября 2001 - 19 января 2002 mkv не полностью/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 466200576, attempting to work around
The source file 'D:/Home movies/Family/1 Архив ДВД 2000-2010/Дети/Дети 1 февраль 2000 - декабрь 2003/Диск 6 15 сентября 2001 - 19 января 2002 mkv не полностью/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 466202624, attempting to work around
The source file 'D:/Home movies/Family/1 Архив ДВД 2000-2010/Дети/Дети 1 февраль 2000 - декабрь 2003/Диск 6 15 сентября 2001 - 19 января 2002 mkv не полностью/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 467124224, attempting to work around
The source file 'D:/Home movies/Family/1 Архив ДВД 2000-2010/Дети/Дети 1 февраль 2000 - декабрь 2003/Диск 6 15 сентября 2001 - 19 января 2002 mkv не полностью/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 467126272, attempting to work around
The source file 'D:/Home movies/Family/1 Архив ДВД 2000-2010/Дети/Дети 1 февраль 2000 - декабрь 2003/Диск 6 15 сентября 2001 - 19 января 2002 mkv не полностью/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 467128320, attempting to work around
The source file 'D:/Home movies/Family/1 Архив ДВД 2000-2010/Дети/Дети 1 февраль 2000 - декабрь 2003/Диск 6 15 сентября 2001 - 19 января 2002 mkv не полностью/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 467130368, attempting to work around
Failed to save title 0 to file D:/Home movies/Family/1 Архив ДВД 2000-2010/Дети/Дети 1 февраль 2000 - декабрь 2003/Диск 6 15 сентября 2001 - 19 января 2002 mkv не полностью/title00.mkv
Track #2 turned out to be empty and was removed from output file
1 titles saved, 1 failed
AndersUA
#9 Post by AndersUA » Tue Feb 22, 2011 8:55 am
Why it takes so long to get answers?
#10 Post by mike admin » Tue Feb 22, 2011 9:34 am
Well, your DVD has corrupt VOB files. Did you author the DVD by yourself? If yes, can you make a very small DVD image that still fails?
AndersUA
#11 Post by AndersUA » Tue Feb 22, 2011 9:45 am
I dont understand your suggestion
You mean record small file?
Why?
I have different disks and all with same error, and only if multiple titles identified. And all of them are playable fine
It doesnt look like corrupt files, rather inability of the program to correctly process multiple titles except the last one.
AndersUA
#12 Post by AndersUA » Fri Feb 25, 2011 1:33 pm
Will I have an answer, please?
#13 Post by mike admin » Sat Feb 26, 2011 10:32 am
The application that you use to create these DVD discs creates broken DVD files. At best, we can add a workaround to MakeMKV to detect and process such broken files, but to do so we need a sample.
portfolis
#14 Post by portfolis » Sun Sep 02, 2012 9:21 am
I have the same problem. Here is a sample.
[link removed]
At the beginning I had "VIDEO_TS" folder. Then I made ISO-image based on files from this folder. And then I tried to save 4 mkv-files from this image with help of MakeMKV. 1, 2, 4 titles - OK, but the third title "corrupted".
So, I tried to process the source files (not ISO, but "VIDEO_TS" folder). The result was the same.
Now I have cut needed title and sent to you (processing of this part has the same results).
Can you help?
setarip_old
#15 Post by setarip_old » Sun Sep 02, 2012 7:13 pm
@portfolis
Hi!
There's no need to go through an intermediate step of creating an .ISO image file.
Simply use your original, commercial DVD as your source material for creating your MKV files.
BTW - Have you checked your original, commercial DVD to see if it exhibits the same problematic behavior regarding the third episode (or any episode)?
Locked
